0 Members and 1 Guest are viewing this topic. Read 31690 times.
It's done.Inaugural ride:http://connect.garmin.com/activity/113683074Battery on the Garmin died during the ride...Pics:http://s1132.photobucket.com/albums/m561/Vintage-Bikes/Olmo%20Super%20Light/
Very nice build. Nice combo of old school and modern. See you went with Campy. How do you like it?
Viggen, I've been following your thread for months.Regarding brake lever reach, you will not find Campy easier to reach than Shimano. In fact, the opposite may likely be true (although much depends on the shape and dimensions of your bars, and on the positioning of the brake levers on the bars). For an easier reach, and for adjustable brake levers that can accommodate smaller hands, I suggest SRAM. In addition, SRAM components are generally compatible with Shimano. For example, many SRAM owners use Shimano cassettes and chains because they find the Shimano cassettes and chains run quieter than the SRAM counterparts. Campangnolo is not compatible with either Shimano or SRAM.The best suggestion I can offer is to stop throwing darts at frames and parts. You've spent way too much time assembling nice, but ill fitting bikes. You'll save money and time by paying for a professional fitting and seeking the advice of a local, experienced dealer or builder of bikes.
Very nice build. Congrats!
Like I said, I already purchased and received the Ultegra 6700 shifter. I find the shifter to be too big for my hands. I have rather small hands for my height or rather for any height...
Viggen, I was commenting on this statement.I own Campy and I like it. However, I've always had issues reaching the brake levers while in the drops (and I have average size hands), so I've been focused on solutions for quite some time, which range from bar shape, bar reach, tweaking the levers with a dab of epoxy to shorten the reach, to switching to SRAM.BTW, while I've never used Campy Athena, your comments regarding the shifting qualities of that grouppo are completely opposite of my experience with both Campy Record 10 and 11 speed. With both those grouppos, shifting is quick, precise, and definite. No mushiness or slop.You've made other comments throughout the thread about fit issues, and others have commented on various fit problems. However, if you believe you no longer have any fit issues, then my previous post is moot.Enjoy the bikes.
Not quite sure from your comments, did you switch to Sram?
