0 Members and 1 Guest are viewing this topic. Read 31683 times.
It's difficult to tell exactly how close the wheel is to the garage floor because of the angle, but that might worry me a bit. If you're headed up into the hills, the back ends gonna be closer to the ground anyway. Couple that with a bump, the suspension compresses, rack moves, it may hit. Those wheels look pricey, less spokes always meant more $$ when I was really riding.....
Very cool. I would measure the distance between the tire and the ground and email the company to see if there is enough clearance. I like the look of the Saris and the BMW. Those new wheels also look cool. It's funny but I know what you mean about wheel stability. Newer wheel designs are lighter and pretty strong for their weight but heavier wheels can feel more stable and they are usually more durable (than low spoke-count lightweight wheels). Your old spokes were probably unbutted and you probably had lots of spokes in the old wheels. This is a good thing on downhill runs but not so much fun when you are trying to pedal the bike uphill! Please let us know how you like the new wheels and the new rack. Both are very cool looking.
Don't be a tease, we need a full frontal bike pic to see that Fuji.
Btw, love the car.
Also, it's good to hear you are liking the new wheels. Your experience on the trainer is most likely psychosomatic (sp?) because the lightest wheels in the world will not make you noticeably faster (or reduce effort) on a trainer or rollers (unless your old ones had really bad bearings).
My new wheels (on my new Powertap set) have very light spokes (DT Swiss Aerolite) and I can feel a slight difference on bumpy down-hill runs versus my Bontrager Race wheels. The new wheels are stiff but not as stiff as the heavy Bonty rims. They ride a bit smoother and are lighter (enen with the Powertap hub) but I believe the Bontrager rims were a bit more solid. Not much but maybe a bit.
Either way, my times for the 41 mile training rides were no better with the new wheels. I did some 1 minute intervals to track baseline power but lost the data due to a stupid mistake that was totally my fault. Need to do it again tomorrow, minus the mistake. Cheers,J
Another alternative, although a little more invasive, is to put a hitch on the Z4 and use that mount. I have it on my Miata and it works quite well. Plus it gives you access to the trunk even with the bikes on the rack.Jim C
Nice bike Viggen. Both of them.Typically aluminum bikes have some pretty thick welds where the tubes join together. So other than a sticker being on the seat tube, that may be the easiest way to tell if the United is carbon or not. Which is not necessarily a bad thing.
