Audio/Video Gear and Systems
The Lab
sts9fan
Capacitor Source?
Capacitor Source?
0 Members and 1 Guest are viewing this topic. Read 1293 times.
Mikeinsacramento
Capacitor Source?
6 Apr 2011, 05:20 am »
I took my powered sub apart to re-cap, as it's 30 years old, LOL.
I need (2) caps. 5600uF, 40WV, 25mm wide, 12mm pin spread. Coming up empty on the google.
TomS
Just relax, ok?
Re: Capacitor Source?
6 Apr 2011, 10:54 am »
Digikey or Mouser should have what you need though with 10mm lead spacing. Try something like this
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P6684-ND
Ericus Rex
Reply #2 on:
6 Apr 2011, 02:54 pm »
If you find Digikey and Mouser search engines a bit overwhelming you might be able to find the caps you need at Antique Electronic Supply:
http://tubesandmore.com/
They carry most of the cap values used in audio but you will pay more for them here.
Mikeinsacramento
Reply #3 on:
7 Apr 2011, 03:40 am »
Thanks for the leads, fellas.
The Lab
sts9fan
Capacitor Source?
