0 Members and 1 Guest are viewing this topic. Read 9412 times.
I tried to make my first pot roast this last Saturday. Did a long slow braise for roughly 6 hours in a Dutch oven at between 200 and 225 for the majority of the time. seasoned with slap ya mama, seasoning salt, and a bit of pepper, seared until dark brown on all sides. Oh yeah, It was two pieces of chuck roast totaling 2.5 lbs and some short ribs. I made roughly 5 incisions into each piece of chuck and inserted halved cloves of garlic. It was seasoned on wednesday night and pulled out to come to room temp on sat morning.The short ribs were fall off the bone tender. The chuck was fall apart tender on the outside. but the center was still dry. I'm assuming i needed more than 6hours for the chuck.I made 3 sauces, a mushroom gravy, a vegetable gravy, and a red wine reduction. All three sauces were pretty good or at least palatable.Here's the problem: the meat had no flavor at all. It was just bland. The juices from the braise were plenty tasty, if a little flat probably because I didnt use a lot of herbs, but the meat wasn't beefy at all.Too much liquid? I did use quite a lot of wine and stock, almost 1 quart of stock and 2/3 bottle of cheap merlot.
Did you salt the meat before cooking instead of after? That would make a difference.
How long did it sit before serving? Brasied meat can dry out fast if let to set outside the brasing liquid for even a short time.
