Mono Block power output
0 Members and 1 Guest are viewing this topic. Read 3159 times.
Rod_S
Re: Mono Block power output
« Reply #20 on: 30 Mar 2011, 05:56 pm »
The 7B's have always been about $500.00 more than the 14 mostly due to the 7's have double the power supply capcitance.  The popular notion that the 14B is 2 7B's in one chassis is not quite true.
That makes sense.
Rod_S
« Reply #21 on: 30 Mar 2011, 05:58 pm »
Thanks for all of the replies.
JBLMVBC
« Reply #22 on: 30 Mar 2011, 07:39 pm »
The 2 7B SST driving my 18"s are rated 628w and 635w
The 2 7B SST driving my 15"s are rated 650w and 648w
The 2B SST driving my 2" compressions are rated 2x 141w
The 2B SST driving my 1 3/4" compressions are rated 2x 140w
Let's recall that in any case you need to double the power to get an extra 3dB so 50w over a 600w amp will make no audible difference. With 98dB/w/m efficiency speakers per channel, the amps can safely deliver the 120dB fortissimos of a live performance. :oops:
