Poll
How much choice do you have in speaker and seat placement?
None, I put them where I'm told
1 (5.9%)
Some, I can argue about it and we compromise
0 (0%)
Mostly I decide but I might compromise a bit
4 (23.5%)
I decide where they go. Period.
11 (64.7%)
Why, what difference does it make?
0 (0%)
I lost my toothbrush
1 (5.9%)
Total Members Voted: 17
Voting closed: 31 Mar 2011, 11:59 am
Open-bafflers only: how much choice do you have in speaker and seat placement?
0 Members and 1 Guest are viewing this topic. Read 6291 times.
JohnR
Open bafflers ONLY!! Boxed speakers - start your own poll/thread somewhere else please!
I'm curious about this one. I've been experimenting a little with seat placement and plan to do some measurements to optimize an upcoming dipole sub project. And I'm wondering - how much say do you have in where the speakers and the listening chair go?
mcgsxr
Unfinished basement, dedicated portion for listening, things go anywhere I want in my OB setup.
Well, I won't move the pool table... :lol:!
gary
My room is relatively small, maybe 14' x 18'? but other than two pieces of my wife's exercise equipment on the sides it's entirely dedicated to the stereo. The baffles are about 2' from the back wall and 1.5' from the sides. It usually sounds best if my chair is pulled forward quite a bit, probably about 1/3 of the way up from the back wall.
gary
JohnR
Hi Gary, is that 1.5' from the driver center or edge of the baffle? They are quite widely spaced if the former - ?
fsimms
Extensive!  :D  But the baffle has sides.
Note the Album on my guest's belly.  :wink:
Bob
JohnR
Um... those aren't open baffle speakers (as nice as they might be).
fsimms
Thanks for the nice compliment.  Here is a picture of the back.
I am very close to getting commercial QRD panels for the wall instead of the towel and then I will not need the glasses to diffuse the back wave.
Bob
JohnR
I know what the back looks like, and I don't think they're open baffle speakers. Does Dennis?
gary
I'm embarassed to post this, partly because it's a crappy cell phone pic and partly because the room looks awful. It will be painted & carpeted soon. Anyway...
The speakers are moved out from where they were in that picture, and my dimensions are from the wall to the beginning of the baffle (now they're about flush with the fronts of the bass enclosures).
gary
fsimms
I think both Jim and Dennis think they are open baffle speakers.  They sound even better when I get them 4 feet from the wall.  Still, they sound extremely good the way I show.
Bob
JohnR
Fine. I give up.
fsimms
Fine. I give up.
Am I being hard headed again!? :scratch:
Sorry.  :(
Bob
jtwrace
    • TIPP YouTube Channel
Bob
I really hope you're joking or misunderstood them.   :duh:
JohnR
The topic is related to the radiation pattern of open baffle / dipole speakers. I'm interested in knowing what external constraints owners of OB speaker are (or aren't) under. To me, "open baffle" implies an attempt to generate a dipole-like radiation pattern over a significant portion of the spectrum.
fsimms
I looked at the Salk website and found this quote from Jim.
But unlike an open baffle speaker, there would be no cancellation at 90-degrees where the out-of-phase signal from the rear of the driver meets the sound from the front of the driver.
Maybe I am did misunderstand them.  :duh:
It does sound like an open baffle.   :thumb:
Bob
« Last Edit: 28 Mar 2011, 08:26 pm by fsimms »
JohnR
Regardless, it isn't. Salk do (or did) make an open baffle speaker, called Archos I believe.
Nuance
Bob
No, they don't. :)  Their open baffle design is the Archos.  Technically it's a hybrid open baffle design.  I will agree that they sound like an open baffle design.  They were my third favorite speaker out of every speaker I listened to at RMAF.  And of those three they were easily the cheapest.
mcgsxr
My placement of speaker and chair is typically the following:
Speakers are in a corner, and are 1.5 feet away from the "side" walls at the closest point to the speaker.  There are bookshelves "behind" the speakers, leading to the gear that is placed centrally in the corner.
They are about 6 feet apart from each other.
My chair tends to be 6-10 feet away from the plane of the speakers.
Pic being worth 1000 words... here is a slightly aged pic, and the chair is not there.
Rudolf
It's my private room - loudspeaker placement is dictated by room acoustics only. Usually those allow less choices than my wife. :roll:
Placement details:
sfdoddsy
Mine are on casters so I can move them in and out from the front wall.
