0 Members and 1 Guest are viewing this topic. Read 13312 times.
Terry, just get a Parasound P7. Come on, you know you want to!
Terry,Thats right, I forgot the preamp has HT bypass just not enough bass management to help out. I understand now, thanks for clarifying. I had similar troubles with the towers. I also was not able to achieve as flat a room response as I did with my previous sierras. With the towers running full range all the time now, EQing the sub was tougher.Can you ellaborate on what you meant about the duals collapsing your soundstage?Thats too bad the the SM didnt work out (unless or course it was behind the couch). I also wonder as you do if any sub will fix the issue.....hmmm. All you can do is buy more subs to try I hope either way, you get things dialed in to your liking!B
That's actually not that loud concerning movies. Movies can have a lot of quiet parts, then crazy loud dynamic parts. With the new lossless audio codecs certain sound effects (such as gunshots and explosions) are sometimes intended to hit over 100dB to give a more realistic experience. I don't recommend watching an entire movie at 100dB or more, but a few quick loud scenes shouldn't kill anyone's ears. P.S. It's extremely easy to hit 100 dB in the bass regions when watching a movie.
TJHUB,Just out of curiosity, if the SVS was working well, why did you get rid of it?I've found my SVS 16-46PC+ works very well with my HT2-TLs (at least in my room).I had a fellow AudioCircle member over this evening to hear my HT2-TLs (he hasn't heard Salks before) and he wanted to hear them full range without the sub. Even with some of the organ music he played, I was surprised how well the HT2-TL held up. It wasn't a good as having the sub, but it was no slouch either. Of course with movies and their sometimes scary bass effects, a good sub is a must for me!
The PB13-Ultra is an amazing all around sub. It was a huge step up in sound quality from my previous sub, a 20-39 PC+. SVS's have always been good at the low stuff, but they really seemed to suffer above 50Hz. The PB13-Ultra was decent. The problem was that I always heard a boxy sound from the sub. It was like I could hear the inside of the box when listening to music. This caused me to look for a sub that was sealed and could keep up with the PB13 for HT. Enter the Submersive HP.The Submersive has no boxy sound whatsoever. It performs flawlessly for music when it the right place in my room. I just wish that same spot worked for HT. I have actually decided that if my buyer this Saturday falls through, I'm going to keep the Submersive and work with it some more. What I hear for music is so good, I need to figure out if I can get the HT side better by finding yet another alternative spot in my room.
I hope you're able to find a way to get the best of both HT and music. Is there a way you could switch between two subs, one optimized for music and another optimized for HT, perhaps using some kind of switch box?Fortunately, in my case my sub location works very well for both in my room
the rythmik 15" subs have that cool dual input amp (optional). you could input your 2 channel into the sub(s) and dial them in for music. then with the HT input, just dial that channel up a little "hotter" using your AVR's bass management.
Have you considered getting a pair of Rythmik Vented Subs (FV15HP)?
No. I figured out prefer the sound of sealed subs. It took me 25 years to figure that out. With today's big amps and very capable drivers, sealed subs for HT perform very well.
What do you have in mind for subs going forward? I know you said the Rythmiks lack power for you, would duals not be enough? I'm sure we will be chatting about it next Saturday as well:)B
At this point, I'll be going cheap. There is a DIY project in my near future. I'll tell you all about it next Saturday.
I thought it might be DIY:) I have a feeling Patrick's behind this
You do know what a bad influence he is.
Thats for sure!You two will soon be attending the BHA meetings.(bass head anonymous)Hi, My name is Terry and I have a problem......
