B100/Bookshelf Speaker Combination
0 Members and 1 Guest are viewing this topic. Read 2228 times.
Laundrew
« on: 19 Mar 2011, 12:42 pm »
Would anyone have any recommendations or experience for a bookshelf style/size speaker system that would work nicely with a future B100 purchase? Height limitations would be up to a maximum of 30 inches and a budget of no more than $5K for new speakers. I keep thinking of the JBL 800’s but they are over budget and no longer in production. I would like to start researching speaker systems for Mrs. Laundrew’s future audio system. As always, any advice is greatly appreciated.
 :D
Project Array 800
Be well...
dirk
Re: B100/Bookshelf Speaker Combination
« Reply #1 on: 19 Mar 2011, 04:43 pm »
These will do fine...
http://www.link-audio.be/Linkenglish/ENGindex2.htm
link k100
Or these:
Link cube:
werd
« Reply #2 on: 19 Mar 2011, 07:10 pm »
Hi Laundrew
If you want i can send you my Mission m71s to try out. They had a stereophile class b (could have been A too) rating and have won product of the year awards in their cost class in other publications. They are good and were about $350 new.
If you want to spend more i would probably look at some pmc bookshelf speakers.
betamax
« Reply #3 on: 19 Mar 2011, 11:58 pm »
I'm running a B100 DA with PMC DB2i's and everything sounds wonderful. Same sweet tweeter as higher models and remarkable bass for their size.
Some reviews:
http://www.dagogo.com/View-Article.asp?hArticle=824
http://www.avreview.co.uk/news/article/mps/UAN/1995/v/3/sp/
Yes, I'm partial, but I bought them because I like them -- rather than liking them just because I bought them.
jaxwired
« Reply #4 on: 20 Mar 2011, 01:13 am »
I can second the pmc db1i recommendation.  I've owned them and they are superb speaker for a small space.  Very few better them under 3k.
Another possibility is Dynaudio.  I'm a dyn owner and I think they are a very nice mate to any Bryston gear.  The contours S1.4 is well under your budget and are truly amazing speakers.
PierreB
« Reply #5 on: 20 Mar 2011, 03:36 am »
Also take a look to ProAc.
