Any good set headphone amps other than Bottlehead?
0 Members and 1 Guest are viewing this topic. Read 2195 times.
Pez
« on: 19 Mar 2011, 02:21 am »
Just curious what else is out there. I haven't had a lot of luck other than Bottlehead. Driving a pair of Beyerdynamics DT880s would love to do something with DHT tubes, , tubed rectification, and something that may be decently flexible with other cans, but am open to any SET design.
JohnR
Re: Any good set headphone amps other than Bottlehead?
« Reply #1 on: 19 Mar 2011, 02:43 am »
Are you looking for kits or just designs?
Pez
« Reply #2 on: 19 Mar 2011, 03:06 am »
Either is fine. A board would be nice, but I'm willing to do P2P soldering.
cryoparts
« Reply #3 on: 19 Mar 2011, 04:22 am »
Most Eddie Current's, Little Dot's, Darkvoice, Decware, some Woo Audio's, Elekit, Trafomatic, Spacetech, Mapletree, Abraxas (Jef will custom make one), Fosgate, a gazillion Chinese amps on eBay, and many more.
Pez
« Reply #4 on: 19 Mar 2011, 04:29 am »
Sorry should have been more specific and said DIY amps.
cryoparts
« Reply #5 on: 19 Mar 2011, 05:47 am »
Ah, I should have figured that out since this is The Lab, I'm a little dense sometimes.
JohnR
« Reply #6 on: 19 Mar 2011, 06:54 am »
There are a good number of circuits here: http://gilmore2.chem.northwestern.edu/projects/index.htm#tubes
I built a version of the "brute force" for some friends but with a simple power supply and they loved it. However the thing you need to watch out for with a headphone amp is noise - levels are actually quite low with phones.
I didn't go through them to see if any are SET.
JohnR
