Poor man's turntable setup
0 Members and 1 Guest are viewing this topic. Read 10846 times.
putz
Re: Poor man's turntable setup
« Reply #20 on: 17 Mar 2011, 02:25 am »
Yeah I was expecting a joke too, wonderful table you got there, I have one as well with Mark III platter.  You got a great deal with the cartridge included, congrats.  The only rub is the stylus is not user replaceable so you have to send it in for a trade-in if/when it's worn out.
Here's Conrad Hoffman's wonder site that has a arc protractor generator.  You can get a $100 arc protractor for the cost of printer ink and a sheet of photo paper.  (Read the instructions, you have to set your printer to NOT scale to paper size)  You have to learn something about effective arm length, null points, and alignment types (Lofgren, Baerwald) to use the generator, but you should learn all of that anyway if you're setting up your own table.  The generator is the third link down.
http://www.conradhoffman.com/chsw.htm
That should get you pointed in the right direction.
So I opened the Generator and I plugged in 3 numbers: 211 for spindle to distance, 66 for inner groove and 120.89 for outer groove. When I printed Protractor it showed me additional numbers: 70.701 for inner null, 107.765 for outer null, 228.342 for effective length, 17.342 for overhang and 23.003 for offset angle. Also mentions to "align cartridge to either grid"
Are the numbers accurate for my tonearm? Is there a simple explanation on how to use the generator. I've been searching online but haven't found anything yet.
I see that AVA offers a Cartridge Alignment tool package for a reasonable price. Maybe I should go that route. I was also considering a Geo-Disk but the AVA product seems like it offers more tools
I ordered the digital scale from Deal Extreme.
Where in Jersey you located Letitroll? I'm in Bridgewater.
orientalexpress
« Reply #21 on: 17 Mar 2011, 04:41 am »
the AVA offers a Cartridge Alignment tool package ,the best $55.00 i ever spend.worth everypenny.:)
lapsan
Letitroll98
  • Too loud is just right
« Reply #22 on: 17 Mar 2011, 05:28 am »
Ok, why would you enter "66 for inner groove and 120.89 for outer groove" when the generator supplies the various suggested numbers for you?  Anyway that's why your result was goofy.  I think you're mixing up null points with inner and outer groove radius.  There are really just two buttons to click, IEC is the industry standard and the safe bet, Typical is Conrad's rebellious nature coming thru and is what he thinks modern records are more likely to be, you can try that if you are also a rebel, I am and do.  DIN is a Japanese standard and not relevant.  Pick the Lofgren A button, which is Baerwald and the easiest to align and the lowest distortion.  Then the generator will produce null points for you, which will be approximately 66 and 120mm.  (There are 120 and 80mm references on the print to check if you've scaled the print correctly, which will be NO scaling)  After you print the protractor you'll have a wonderful arm specific arc that when lined up solves all those overhang and alignment issues for you, way different than the universal protractors that make you go thru all sorts of gyrations to get proper alignment.  Both grids are set up on the two null points, you can use both for super accuracy, or either one, if one is correct both should be, if not you don't have the protractor lined up correctly.  To get the hole lined up, cut a cross directly over the middle spot and gently squeeze it over the spindle, don't try to cut a round hole, you can't.  When done, the stylus should track perfectly over the arc from in to out, if it does you are in perfect alignment.
There are more complete discussions on a board that shall forever remain nameless in my posts.  Can't comment why that's dirty laundry.  But just sent a note to Conrad, he's a great guy.
You'll love the digital tracking force gauge.
I'm in South Jersey, a bit far from Bridgewater.  But please feel free to ask any more questions on the thread or in a PM.  Have fun!
Letitroll98
« Reply #23 on: 17 Mar 2011, 05:31 am »
hallo all,
there is a way to cheat with the alignment.
you can twist the cartridge in the headshell to compensate for lack of distance from the pivot to tip....eff. length.
Grado cartridges has a short distance from diamond tip to mounting screws, so it will probably allow Loefgren alignment on the Jelco tonearm.
i prefer the Loefgren points when at all possible, but i do fine tune alignment by ear.
regards,
bas
B-nut!!!  Waz up??  Welcome aboard!
orthobiz
« Reply #24 on: 18 Mar 2011, 11:54 am »
lapsan
Absolutely!
Paul
