Thermal grease choices?
0 Members and 1 Guest are viewing this topic. Read 1245 times.
nodiak
« on: 14 Mar 2011, 08:41 pm »
Is Arctic Silver #5 ok to use for SS amp? - using mica washers under mosfets, then on heatsink. I bought AS5 but can return it if something else is better. Have read method is to coat both sides of mica washers with thermal grease.
Wondering if anyone has used AS5 successfully.
Thanks.
wushuliu
Re: Thermal grease choices?
« Reply #1 on: 15 Mar 2011, 03:56 am »
Should be fine. It's non-conductive. That's why I used for the DCB1 hot-rod.
nodiak
« Reply #2 on: 15 Mar 2011, 05:16 am »
Thanks wushuliu, saves a return  trip to RS.
