0 Members and 1 Guest are viewing this topic. Read 15431 times.
If you aren't getting the sound you want with 50 or 100 watts then a 600 watt bruiser won't help either. cityjim
And if you are clipping your amps you're most likely driving the speakers too hard.
You can buy some 1000 watt monos all you want. Truth is you'll never use 80% of the amp.
I agree quallity is best. That's why I use full class A tubes on mine. I've tried many a brand of solid state amps. Tried three highly hyped class D amps. My experience was anytime I moved away from class A and especially tubes the sound degraded.
Let's revisit amplifiers. The more watts an amp has the more amplification stages that amp has.
There are people who wander around thinking they're Jesus Christ ... but that doesn't mean they are. The rest of us just think they're sadly deluded. Please keep on topic here Andyr. You are quite free to believe that 100w is more than enough but puhleeze - have the clarity to make it clear that this is just your opinion. Not fact. As it's your opinion you need 900 watts just to hear "your" speakers in "your" house. Simple fact is my Yamamoto A-08 with its whopping 2 watts per gets pretty loud. Even running my 20.1R's. This is with a sub of course. You don't need 800 watt amps if you run a sub like I do. And lets face it, maggies don't do bass. Don't lecture people as to how loud they should be listening. I wasn't.Not never. The truth is - IMO - that for 99% of the time, you won't be using more than 10w. IE. only 1%! But to faithfully deliver the leading edge of some transients, you may need 100 times that, for a millisecond. The "1,000w monos" give you this headroom; a 100w tube amp does not. Here we go again, your full of buzz terms today Andyr. Now we've moved onto headroom. You were on Jesus a bit ago.I can understand where you're coming from and have no problem with your liking for Class A and tubes. But some of us don't want to put up with the wasted energy that Class A implies (ie. heat). And when we find an ss amp designer like Hugh ("Mr AKSA") Dean, we find very nice-sounding amps. OK Jokes aside, if you can afford $12,000 like me for 20.1R's then running the air conditioner is not even an afterthought.And in terms of "sound degrading" ... I am positive that my 100w Soraya Class AB ss amp will deliver better sound from Maggie bass panels than your Class A tube amp. And bass control is one thing which is particularly important to me! Good one Andyr. Again maggies don't do bass. You can talk bass control all you wish. Never seen any Magnepan anything shake windows or move your clothing. Even when I borrowed a pair of Krell Evolution 600 watt monos my 20.1R's never shook the room. So your obtuse wattage opinion deflates itself. BTW, that was 1200 watts per channel of Krell power into 4 ohms. Simply would eat a soraya amp for lunch.Not as I understand it. What they do have is more parallel output devices. Depending on the amp of course. Keep reading Andyr.Regards,Andy
cityim: Please keep on topic here
I will change the fuses on my MG 20.1 with the new hifi tuning supreme 3fuses.This should bring a lot.Will post some photos when done.
AndyR,You're inspiring me to semi-greatness as I happen to have a whole bunch of unused Acme fuse holders.That and jk's photo are going to make me actually do something.
What I am a bit nervous about is that if I go fully active, I will have nothing between amp and driver. To tell the truth if I go active I will probably put a fast blow fuse in first and play at low levels for a while before I get to a comfort level if can live with.
