wiring multiple subs
0 Members and 1 Guest are viewing this topic. Read 6468 times.
sts9fan
Re: wiring multiple subs
« Reply #20 on: 21 Mar 2011, 05:28 pm »
I wish it had single ended connections
JohnR
« Reply #21 on: 22 Mar 2011, 07:20 am »
'Tis an issue with a lot of the "pro" crossovers.
I think the DCX can be configured for 1-in 6-out. (No hands-on experience but I do recall reading it somewhere.)
DougSmith
  • What will the next hundred years bring?
« Reply #22 on: 22 Mar 2011, 12:17 pm »
It is 3 in, 6 out.  The inputs can be mixed in the unit.  I actually have mine connected to a single ended receiver and amps using home-wired adapter cables.  It works just fine with no noise at all.
TomS
« Reply #23 on: 22 Mar 2011, 12:20 pm »
XLR to RCA adapters work fine on mine for SE.
jtwrace
    • TIPP YouTube Channel
« Reply #24 on: 22 Mar 2011, 12:23 pm »
Me too.  I had DH Labs make me a 1m cable that is RCA > XLR.  No problems here.
sts9fan
« Reply #25 on: 22 Mar 2011, 12:55 pm »
So what can the DCX do that the Mini can't?  I don't need 6 outputs.  Putting a mono signal into the mini I can control four subwoofers which is one more then I plan to have.  So practically what is to gain for an extra $160?
TomS
« Reply #26 on: 22 Mar 2011, 03:15 pm »
The one reason I use the DCX vs Mini is that it can sum L+R on its own prior to xo and eq.  If you're already mono then no problem for the Mini.
sts9fan
« Reply #27 on: 22 Mar 2011, 03:24 pm »
Good point.  Although I can do that for the cost of 3 RCAs and a few resistors. Right?
http://www.rane.com/note109.html
TomS
« Reply #28 on: 22 Mar 2011, 05:08 pm »
Sure, or an op amp, etc., just more connectors, boxes, etc I don't want.
sts9fan
« Reply #29 on: 8 Apr 2011, 05:28 pm »
Amp? Check! (Parasound HCA1000)
MiniDSP? Check!
Tapped Horn Kits? Shipped!
Drivers? Shipped!
Let the fun begin.
bigjppop
« Reply #30 on: 10 Apr 2011, 04:17 pm »
I'm glad to see I'm not the only one on the miniDSP/Anarchy tapped horn bandwagon. I'm still trying to figure out exactly what I want, but at this point I'm looking at two of the tapped horns augmenting my Omega 3i single driver speakers. I drive the Omegas with a Tubelab Simple SE that I built and a Bottlehead quickie preamp.
I've still got to figure out what I'm going to use to drive the subs. I'm hoping for something cheap and was thinking about just using a plate amp from Parts Express to drive the pair but then I'm looking at dual mono subs instead of stereo subs. Probably not that big of a deal, but still...
I'm also curious if anyone has tried, or given any thought to, the miniDIGI as an add on to the miniDSP. I'm using an apple TV as a music server and would love to run the toslink to the miniDIGI, wire a volume point to the miniDSP, and try going without a preamp.
If that doesn't work for me, I'm also thinking about building a DAC, my Bottlehead Quickie, and the miniDSP into a single chassis so that I can run the apple TV into this Frankenstein device and then pull the outputs to my Tubelab Simple SE and then to the sub amplification. This process might be a little more involved, but could be cool.
Any thoughts?
sts9fan
« Reply #31 on: 10 Apr 2011, 05:03 pm »
Got my tappedhorn kits yesterday!!
sts9fan
« Reply #32 on: 12 Apr 2011, 04:39 pm »
Well it appears that the miniDSP can't handle input voltage from my preamp.  I have it set on the 2vrms setting and my pre is rated at 2vrms.  Anywhoo back to the drawing board.  Anyone got an extra dcx laying around?
jtwrace
DougSmith
« Reply #34 on: 12 Apr 2011, 05:09 pm »
Where are you going to put them!?
sts9fan
« Reply #35 on: 12 Apr 2011, 05:34 pm »
Wherever they sound best!   Honestly I am not sure yet.
Rclark
« Reply #36 on: 19 Apr 2011, 01:20 am »
Why would one need a DSP?
What if your preamp has dual subwoofer outs? Would you still need a dsp (only running two subs)? What are some reasons for using a DSP for subs?
sts9fan
« Reply #37 on: 23 May 2011, 04:11 pm »
So I know have my DCX and all three subs.  I just finished the second tapped horn this weekend.  Well they are functional but currently have no finish.
Now that I think about it I am not sure why I was getting distortion from the miniDSP.  Maybe I could have used it but I gave up pretty quick.
I think Thursday I should have everything in place to start taking measurments.
Rclark
« Reply #38 on: 6 Jun 2011, 07:43 am »
Can you please explain to me what it is you are planning to do exactly?
The reason I ask is because in my system build I have two subwoofer drivers and plan to buy enclosures and amps for them but don't know what to do beyond that point.
I have a DAC/PREAMP (Emotiva XDA-1) and a CDP and that's all the hardware I have for now.
 Sorry to hijack; I thought I could learn something that could help me with my situation in this thread but you guys are talking a few steps beyond beginner. This does, however, seem like the place to be.
