MFW-15 Power Handling
0 Members and 1 Guest are viewing this topic. Read 2583 times.
dbshelton
« on: 8 Mar 2011, 12:11 pm »
What would the maximum RMS and also peak wattage be for an MFW-15 in sealed 3.0 cu ft box?
mojave
Re: MFW-15 Power Handling
« Reply #1 on: 8 Mar 2011, 02:59 pm »
The driver is rated for 225 watts. I happen to have a model open in WinISD Pro right now. With that amount of power in a 3 cu ft box it won't exceed X-Max (13 mm) unless you are trying to play content below 7 Hz. Per Mark Seaton the X-Mech is 20 mm. Therefore it should handle peaks of 550-600 watts without exceeding that excursion.
Danny Richie
« Reply #2 on: 8 Mar 2011, 07:52 pm »
I know many that are using them with 300 watt or 350 watt amps with no problems at all.
skeeter99
« Reply #3 on: 9 Mar 2011, 01:17 am »
The AV123 MFW-15 amp was 350watts. I don't know all the specs for the factory enclosure though.
tesseract
« Reply #4 on: 11 Mar 2011, 07:48 am »
The V1 is said to be 350 watts. The V2 and V3 amps are said to be around 500 watts.
skeeter99
« Reply #5 on: 11 Mar 2011, 03:20 pm »
Wow I never heard that. Shows how much stuff changed there from day to day ...  :duh: I have V1's (still working perfect btw :D) and knew they were 350watts.
sandbagger
« Reply #6 on: 11 Mar 2011, 03:57 pm »
I still have a very hard time believing those ever made anywhere NEAR 500W.
I have to believe that was all a hype " here is this new amp to replace your blown up one, and its even more powerfull"
murrel
« Reply #7 on: 11 Mar 2011, 09:07 pm »
V1 was around 350 watts
V2 was around 375 watts
V3 is around 400 watts
Murrel
tesseract
« Reply #8 on: 15 Mar 2011, 06:31 am »
Thank you, Murrel. This is why I avoided making absolute statements...   :peek:
murrel
« Reply #9 on: 15 Mar 2011, 10:42 pm »
tesseract,
you are welcome
