Custom built N3S Center and A/V-1RS in Walnut....PICTURES!!! :-)
0 Members and 1 Guest are viewing this topic. Read 12380 times.
chip
So what is the difference between these 3 items?
Zinsser Seal Coat
Zinsser Shellac clear
Zinsser Shellac amber
Peter J
  • Hmmmm
Zinsser Seal Coat
They're all shellac. Seal coat is dewaxed, clear and amber aren't. The only difference between the latter two is color.
http://www.rustoleum.com/CBGCategory.asp?cid=53
If you're thinking of using shellac, bear in mind its solvent is denatured alcohol. Many won't have that handy so you'd want to get some when purchased or you'll end of with no way to clean brushes and such.
Outofthewoods
  • Fallen Enclosures, Inc. Crafted with Passion
A few more pics with the grilles attached.
chip
What does dewaxed mean in the seal coat? Sorry but I am confused a tad... :scratch:
Groundzero
Normal, non-dewaxed Shellac can impair adhesion of anything you put on top of it. If you are putting another finish over the Shellac it is best to use dewaxed.
chip
So is this somewhat of a good procedure to follow -
Posted by DanceswithBeers over at HTGUIDE
For any oil finish, you'd follow the same steps basically:
1. Sand the entire project up through 320-400 grit.
2. Fill the grain if you want a perfectly smooth surface***
3. Apply the the oil-based finish liberally to the surface with a clean, lint free cloth, application sponge, or brush.
4. Wait about 5 minutes for it to soak in and wipe up the excess (this wait time varies depending on the product).
5. Wait 24 hours.
6. Repeat 3-5.
7. Wait 24 hours.
8. Sand with 400 grit.
9. Apply another coat and wipe off (when I wipe off, I typically just wipe with a t-shirt using one piece of it. I'm not wiping off every bit of finish, but more smoothing it out and wiping up enough excess to avoid any runs).
10. Repeat steps 7-9 until the finish starts building to the surface.
Once the finish is nearing the surface, I will typically start with finer sandpaper and then steel wool between coats. When it starts looking how I want it, after dry, I buff with 0000 steel wool and apply one more very light coat.
Your time to finish will differ depending on the wood type. For a smooth, closed grain wood like maple, you don't need much. For something like mahogany and walnut, the wood will soak up more of the oil. The general finishes tend to build up faster, more like poly. With the Danish oil, the build up was really slow. I prefer a lot of thin coats in general.
Outofthewoods
Hi Chad,
Were you able to take delivery today???
The butterflies don't fly away until I hear that you received everything in perfect order! :peek:
Ruben
chip
Nope because it was day time. I missed it Saturday by 10 minutes. :duh:
I called fedex today and will pick them up tomorrow. Odd thing is my tag says 1 package.
Anyways I will follow up with you hopefully tomorrow.
Outofthewoods
Thanks for the update Chad.
One package? :scratch:
Did you give them both tracking numbers?
Ruben
chip
Picked up and unwrapped and no harm done that I can see. Boxes were in good condition.  :thumb:
Now I need to figure out my staining process and build the crossovers that are still sitting in there boxes  :duh:
« Last Edit: 24 Mar 2011, 12:44 am by chip »
Outofthewoods
Great news!!! :dance:
It's been quite the journey getting here...I'm glad you're happy with how everything turned out.
If you end up needing more veneer to test your color with just let me know. I have a couple sq ft left.
Thanks again Chad. :beer:
Ruben
chip
Well I began the staining process yesterday
Randall Kepley
  • Kepley Custom Cabinets & Furniture
THats it? 1 lousey pix ? Dang man, weve been waiting on this to start to see whats what and we get 1 lousey pix!  :lol: Come on you can do better than that. R.K.
corndog71
  • Some people call me Rob.
Lookin good! :thumb:
chip
Thanks for the comments -
Center -
Another Pic of the rears -
« Last Edit: 28 Mar 2011, 01:14 pm by chip »
chip
More pics -
Rear speaker mounted -
Center channel -
Outofthewoods
They look GREAT! :thumb:
You did an awesome job with the finish Chad.
Have you been able to listen to them yet?
Ruben
chip
I finished them up yesterday. Finished mounting today. I am waiting for the center channel board to dry that is going above my TV. I did plug them in and test them just to make sure they all played.
Maybe have it all hooked up tomorrow....and listen a bit.
Danny Richie
Man, those realy look nice.
Wow, those look amazing! Nice job!
