0 Members and 1 Guest are viewing this topic. Read 16130 times.
I should have thought ahead a bit .... The next question which I am going to be asked is : " What amps have you been considering so far " ? Eastern Electric, Rogue, Ayon so far .....I thought I had found my new amps when I started reading about The Eastern Electric M156 monoblocks ... ALL of the professional reviewers seem to all say these amps do NOT sound overly tubey, but more like great solid state with a tube like richness in the midrange ...... Then I read several customer reviews ... and to a fault, they ALL say they consider these amps to be on the warm and euphonic side ..... Damn ... foiled again with confusion.BTW, I listen loud, and I listen to EVERY kind of music on 88db sensitive speakers .... so I am looking for POWER !!!
You don't need tube amps, you need a better SS amp. Trying to find a tube amp that sounds like SS isn't going to happen IMHO. You should look for a more "Liquid" SS amp. Try the Electrocompaniet AW-180 or the Hegal H200.
You might read this....one year ago... http://www.audiocircle.com/index.php?topic=77174.0
Tube preamps can sound excellent, BUT, while more reliable than tubed power amps, they are FAR too dependent on a "quiet" good sounding set of small signal tubes to perform at their best. Modern small signal tubes are not very good,
14 pages ???
Not trying to be a pain Freo, but how do you know your FET preamplifier is accurate?? When have you heard my preamplifiers and how do you know how they sound, that they are inferior?? In general I am wondering how you came to your conclusions? Cheers.
I'm afriad this makes NO sense to me .... Adding a preamp is unnecessary. It only adds more in the signal chain ... more wires ... more electronics ... I have full control of the volume without using a preamp .... As far as that goes, if I wanted to, my EE DAC has a volume control on it .... Whay would I EVER want to add another ?
Not true. The Dodd Buffer has a remote control.
Thank you so much ... This just may be the ticket
Well, Check out the internet on the Threshold FET-10, and you will see for yourself. It's been updated with new caps, and has 200VA power supply. The unit has been checked with various test equipment to ensure performance.
Please do not read too much into the comments. It's common sense to state that tubed preamps will vary much more in performance, primarily due to the tubes used in them. BTW, I also have a tubed preamp that tests, measures, and sounds excellent as well.
Hi Freo,How do we know the "new caps" make it more accurate, in absolute terms? I can see in one's particular system it sounds better, but that is not absolute terms. Unless the value of the caps (in uf) are changed, how does changing the caps affect the specifications? I think the answer is we agree that parts like caps sound different.I agree the saying seems to be that a heavier power supply/transformer sounds better, but is that true, in class A operation/preamplifiers? In fact a heavier power supply could make it sound worse because the parts favor a portion of the audio band, such as bass, mids, or highs, as examples. (It is true that class AB, B operation does require more voltage stability thus increased regulation.) In preamplifiers (class A operation), the last thing I look at is the power supply rating/transformer size. Rather I look at the lack of reactance (minimizing/eliminating of chokes), how flat the response is of the power supply. (I bet you never heard that before from the rags etc. )A tube preamplifier can have the same specs as the SS, and will sound different. I Also agree with your assessment that different tubes of the same type sound different.IMO, a review is not an accurate way of testing in absolute terms, but to the reviewer's own system and room acoustics. I find changing to NOS changes the sound, to often times a detriment, from absolute accuracy.I think it is good to have dialogue that digs into the beef, so to speak.Cheers Freo.
LOL ... ignored due to too much alchol consumption ..... Many consider the DNA-500 the best solid state amp money can buy under $20 grand My amp is certainly not the issue, but thanks...
Steve,On the whole, I think we agree more than disagree. Your points about reviews in general are well taken. I have tried in the past to make similar points, and was taken to task by some over this matter.
To this point, I have been turned off completely by the syrupy, overly mellow, and colored sound of most tube amps.
I owned the DNA-500 and it is a darn fine amp, but nowhere near the best amp under $20k...not even close.What you are describing in terms of wanting to add to your sound are the weak points of the DNA-500.George
Yes Freo, I think we mostly agree, and your point of tube longevity is well taken. I am not sure what you mean about grading of tubes, but if it means someone has "evaluated" the sonic quality of brands, I have read such and have serious doubts concerning their conclusions, at least in absolute terms. If you meant something else, then I misunderstood you. I guess one of my main points is that it seems evaluations are made by simple measurements and/or simply testing in the evaluator's system, so the conclusions are not in absolute terms. There is a difference. Anyway, if I am correct in understanding Downsize, his system may be just slightly sterile sounding, wants it a little more natural, but not Would I be correct Downsize? IF so, I heard Downsize's description (quote above) at the 2004 or 05 CES/The Show in abundance. Cheers.
