BDP-1 REVIEWS
0 Members and 1 Guest are viewing this topic. Read 70579 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP-1 REVIEWS
« Reply #40 on: 6 Jun 2011, 09:27 pm »
Don't paint us with all with that Linn/Naim indoctrination!
My apology sir.
james
Re: BDP-1 REVIEWS
« Reply #41 on: 8 Jun 2011, 07:19 pm »
MEMO – Newport Audio Show Feedback
SUBJECT – Bryston BDP-1 Digital Player
June, 2011
Hi folks
Please find attached a quote from a reviewer Andre Marc of AV REV Magazine regarding the Bryston BDP-1 Digital Player at the recent Newport Audio Show in California in the YG Acoustics demo room.
“I heard the Bryston BDP-1 in Newport. It was the BEST sound at the show with in the YG Acoustics room with Tenor electronics. They were playing back a 24/96 vinyl rip. I was blown away.
The build quality of the BDP-1 is tremendous.”
Andre Marc, AV REV.com
Re: BDP-1 REVIEWS
« Reply #42 on: 8 Jun 2011, 11:18 pm »
Hi Folks,
Was informed today and got a copy of the BDP-1 review which will appear in the September isssue of Absolute Sound Magazine.
james
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
Re: BDP-1 REVIEWS
« Reply #44 on: 16 Jun 2011, 11:24 am »
http://www.stereophile.com/content/bryston-bdp-1-digital-audio-player
Its always great when the test measurements reinforce the listening experience aye :thumb:
james
jjc1
Re: BDP-1 REVIEWS
« Reply #45 on: 20 Jun 2011, 03:02 pm »
Hi Folks,
james
Hi James. Do you have a link to this review like you sent for the Stereophile review?
Re: BDP-1 REVIEWS
« Reply #46 on: 20 Jun 2011, 03:12 pm »
Hi,
No I just have a copy for proof reading the technical stuff.
I will have a PDF once the review is in print.
james
terrycym
Re: BDP-1 REVIEWS
« Reply #47 on: 20 Jun 2011, 04:03 pm »
Hi,
james
Is this normal in the trade?
They're giving you an opportunity to modify and update their review on Bryston product before they publish?
Re: BDP-1 REVIEWS
« Reply #48 on: 20 Jun 2011, 04:12 pm »
Hi Terry - they send you a copy and you are only allowed to comment on the technical stuff or offer a Manufacturers comment.  They will not let you speak with nor influence any reviewer or change the opinions expressed in any way.
james
« Last Edit: 21 Jun 2011, 11:24 am by James Tanner »
Re: BDP-1 REVIEWS
« Reply #49 on: 20 Jun 2011, 08:02 pm »
Hi Folks,
Just got a 17 page review of the BDA-1 and BDP-1 which will appear on-line June 30th from 'Secrets Of Home Theater'.  There are some extensive measurements made on the unit but the one comment is worthy of note -
"The jitter spectrum below indicates an average of about 5-8 pico-seconds"
james
mr_bill
Re: BDP-1 REVIEWS
« Reply #50 on: 21 Jun 2011, 12:53 am »
Hi Folks,
james
Referring to the jitter level of the BDP-1 or the BDA-1?
Re: BDP-1 REVIEWS
« Reply #51 on: 21 Jun 2011, 01:02 am »
BDP :thumb:
James
mr_bill
Re: BDP-1 REVIEWS
« Reply #52 on: 21 Jun 2011, 02:36 am »
BDP :thumb:
James
James,
I really think you are ahead of your times with this product and you've hit a home run.
It's taken a while for me to get used to this type of product (I own a touch - streamer), but the more I look at the BDP-1 the more I like it's concept.
Davesworld
Re: BDP-1 REVIEWS
« Reply #53 on: 21 Jun 2011, 04:52 am »
James,
I have been waiting for years for something like this, just a high end streamer with no dac built in. I largely blame the iPod mentality for the distraction away from streaming music off of a centralized server and the internet which many were already doing before the iPod.
 I bought a Turtle Beach Audiotron in 2001 which is basically a network streamer. It's a standard 1u/17" wide device with a 2x40 display. It will play files from a windows network share and again from the internet but it is limited in many ways, it will only play wav, mp3 and windows media stuff, not protected. The spdif also will only do 32k and 44.1k but the built in sound will encompass stuff like 22khz and play it out the analog ports. It'll play 48k streams but the sound is slow, like playing a 45rpm record at 33 speed.
 Back then (ten years ago) we hounded TB about FLAC support and ogg etc but they made an excuse that the device didn't have the power to decode. I suspect the fact that it was CE powered that they probably could not incorporate the Codecs. There was a workaround though if you were running a Samba server in Linux and that was using perl scripts to convert to wav on the fly and flac files were seen as wavs by the Audiotron. In 2004 TB discontinued the device and later on discontinued Turtle Radio. We learned of a secret password to set the Audiotron to look for an xml file in a windows share or in my case Samba. I have an Excel tool that allows editing this xml file. I still use this as well as a Squeeze Touch. The Audiotron will not play aac streams so for stuff like DI.fm's premium and Jazzradio, I simply use the higher rate mp3 streams. I believe the device actually predated 2001 as one of the major PC OEM's had it and then sold it to TB.
All this time the closest thing was Squeezebox but it required a special server which was more difficult to set up on some Linux distros than it is now and the idea of running a windows based music server sickened me. There were also a plethora of media players with built in hard drives which I also thought were the wrong approach. Also as I lamented many times, we saw iPod docking stations and more docking stations. It was difficult to find any Audio news without seeing yet more iPod docking stations and they still keep coming. Enough already! I never liked the ipod and it's codec support. It's useless to me. Put a tube output or eny exotica you can throw at it and it is still centered on an iPod and it doesn't get any better. I blame the HiFi manufacturers for getting caught up in this dead ended nonsense. When I walk into my home, the music should just be there on my server and ready to play on real audio equipment at the push of a button. I shouldn't have to pull my phone or music player device out of my pocket and plug it in first.
I do have a squeezebox touch which works well but I don't really know what to do with it. It looks a bit out of place in my stereo system and I usually use the remote anyway. What I really wanted was something like the transporter without the built in DAC. I see no point in building a DAC into something when you will bypass it soon anyway when a better DAC comes along. When I saw the BDP-1 and what it was made of, I got pretty excited. I'm very familiar with the hardware inside, especially the modified ESI Juli@. Yes, just give us a bit perfect output and we'll do the rest. Now where to buy one? I'm in Everett, Wa.
SHV
Re: BDP-1 REVIEWS
« Reply #54 on: 27 Jun 2011, 04:55 am »
"Now where to buy one? I'm in Everett, Wa."
I had the same question; with no local Bryston dealer available.  Ordered on line from AudioAdvisor and the BDA/P combination arrived in a few days.  Very happy with it.
Re: BDP-1 REVIEWS
« Reply #55 on: 28 Jun 2011, 04:25 pm »
Hi Folks,
The review of the BDP-1 in Secrets of Home Theater.
It is nice to see the measurements support the listening experience :thumb: :thumb:
http://www.hometheaterhifi.com/media-servers-products-menu-column2-44/1337-bryston-bdp-1-music-server-and-bda-1-dac.html
james
headshrinker2
Re: BDP-1 REVIEWS
« Reply #56 on: 28 Jun 2011, 04:54 pm »
James,
Congrats on another positive review of the BDP-1!  I am finding it odd that some of the reviewers don't give audio quality more focus in their write-ups.
Re: BDP-1 REVIEWS
« Reply #57 on: 28 Jun 2011, 05:37 pm »
James,
Hi,
A lot will depend on the reviewer and the magazine.  For instance the review coming next month in Absolute Sound is nothing but about sound and his comparisons.
The thing I like about the Secrets review is it truly reinforces that all the great press we have been getting about the sound of the BDP-1 Digital Player from customers as well as reviewers is born out with the state of the art measurements - which for some matter more :thumb:
james
Alpha10
Re: BDP-1 REVIEWS
« Reply #58 on: 28 Jun 2011, 06:28 pm »
Another good review, congratulation. It must be the engineer in me that likes seeing all the measurements  :duh:
Re: BDP-1 REVIEWS
« Reply #59 on: 1 Jul 2011, 11:38 am »
FIVE STARS:
