BDP-1/2 Recommended Interfaces
0 Members and 1 Guest are viewing this topic. Read 286312 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP-1 Recommended Interfaces
« Reply #260 on: 8 Mar 2012, 12:18 pm »
I agree very much with this statement.  The BDP-1 sounds great but the user interface is not good.  I have a high tolerance for quirky software but I am reaching my limit.  I have only x amount of time to listen to music and I really don't want to spend that time trying to get the dang thing to work.
Hi,
Sorry you are experiencing problems but it has to be a network issue not the BDP-1.  The BDP-1 has nothing to do with wireless network connection issues.
james
gil99
« Reply #261 on: 8 Mar 2012, 01:50 pm »
Hi,
I am using the mancave option (d-link router) with the BDP-1 and control it with my ipod using mpod and mini-2 and everything is working like a charm.  Make sure you configure mpod with the right setting to access the BDP-1.  I had some minor problem at the beginning due to incorrect settings. One thing I find is that you cannot save a playlist using mpod (might be a bug) but use the bryston mini-2 to create your playlist then it will bwe available with mpod. (don't forget to refresh cache in mpod after creating playlist with mini-2)
SHV
« Reply #262 on: 8 Mar 2012, 02:23 pm »
The IPad works very well as a BPD-1 controller. I wonder if a used IPad 1 can be bought for not may $$, now that Gen 3 is released.
jjc1
« Reply #263 on: 8 Mar 2012, 03:04 pm »
James,
Is it ok to run both the interfaces at the same time? Max and Mpad, need to toggle back and forth so I can see the album art in Max.
Sometimes I have 4 interfaces running at the same time with no problems. Different interfaces show different info, ie; Max shows type of file  (like wav,flac etc.) whereas MPad does not.
    I had many problems when I first got the BDP1 about a year ago, but recently all interfaces have been working just fine. I always use the IP address because BRYSTOn-BDP-1 never seems to work.   Could any of these problems be associated with the type of  man cave connection? I use a wireless adapter and do not seem to have the problems eveyone here is having.
setamp
« Reply #264 on: 8 Mar 2012, 04:55 pm »
Which brings me back to my original question.  Is there a wired interface that can be used.  My wireless connection is made through a Trendnet TEW654.  It works flawlessly to stream movies from netflix but is problematic with my ipod/mpod.
Hi,
james
NMG
« Reply #265 on: 9 Mar 2012, 03:56 pm »
if you connect your network to the BDP-1 with an Ethernet cable and use Gnome (downloaded from Internet) as the interface, it should work reliably.
Neal
setamp
« Reply #266 on: 9 Mar 2012, 07:07 pm »
Because of location, I can't wire my BDP-1 to a router.  That's why I am currently wiring it to a wireless bridge.  Can I connect a laptop via ethernet cable to the BDP-1 and use gnome?  If I set up a wired connection to the BDP-1 would I lose my wireless connection on the laptop?  I am running Windows Vista and currently access the internet with a wireless modem.
NMG
« Reply #267 on: 9 Mar 2012, 10:27 pm »
Look at Netgear Powerline Ethernet Adapters. Run from router to electrical outlet, then from another electrical outlet to BDP-1. Solved my problem cheaply and easily. You will not lose your wireless connection if you connect BDP-1 this way.
Neal
setamp
« Reply #268 on: 10 Mar 2012, 09:43 pm »
I tried Gnome this morning - it's a nice bit of software!  I didn't have any connectivity issues and I love the interface.  I like being able to pull up lyrics and links as well.  Thanks for the advice.
« Reply #269 on: 13 Mar 2012, 09:26 am »
Hi folks
The long hold function on Mpad interface is not working if you downloaded software update IOS 5.1 from Apple. Berrie tells me there is a fix on the way.
James
« Reply #270 on: 22 Mar 2012, 10:58 pm »
Hi James,
You may already be aware of this program; MAX ripper for Mac computers. It's much like DBpoweramp; bit perfect and it allows for imbedded tags!
James from Absolute Audio
« Reply #271 on: 2 Apr 2012, 05:44 pm »
Minion version patch Works with Firefox 11
http://www.gargan.org/en/Mozilla_Extensions/Music_Player_Minion/
james
« Reply #272 on: 11 Apr 2012, 02:41 am »
Hi Folks,
Chris is working hard on improving the Bryston MAX interface for the BDP-1 -will be called the MAX 2 and will be available as a download with a new software update.
james
« Last Edit: 11 Apr 2012, 10:38 am by James Tanner »
dlach
« Reply #273 on: 11 Apr 2012, 03:10 am »
James,
It looks great.  So, how do we get MAX2 once it becomes available?
Take care,
Denny
SHV
« Reply #274 on: 11 Apr 2012, 03:17 am »
That is a teaser.mov since it seems to be for a BDP-2....isn't it a bit early in the product cycle for a BDP-2??
Alpha10
« Reply #275 on: 11 Apr 2012, 07:34 am »
I should imagine that it is just that they call them bdp-2, bdp-3 etc when you have more than one device on the same network?
Cheers
« Reply #276 on: 11 Apr 2012, 10:25 am »
James,
Take care,
Denny
Hi Danny
Not sure when Chris will be finished with it - hoping about a month - then we will offer it as an upgrade through new software.
James
« Reply #277 on: 11 Apr 2012, 10:35 am »
Cheers
Correct - I have BDP-4 at home - I will repost the link.
james
jjc1
« Reply #278 on: 11 Apr 2012, 03:24 pm »
 :scratch: :scratch:
james
  Huh?   :scratch:
Alpha10
« Reply #279 on: 11 Apr 2012, 05:39 pm »
:scratch: :scratch:  Huh?   :scratch:
If you have multiple BDP's on the same network you need to call them different names; bdp-1, bdp-2, bdp-3, bdp-x, so you know which one you are controlling and so they don't all start playing the same tune  :lol:
Cheers
