BDP-1/2 Recommended Interfaces
0 Members and 1 Guest are viewing this topic. Read 285455 times.
Phil
Re: BDP-1 Recommended Interfaces
« Reply #180 on: 1 Oct 2011, 04:18 am »
If you like Gnome and have had trouble installing it on a mac, there is a work around, if you could call it that.
Since I need a windows environment on my iMac for work, I installed VMWare fusion 4.  This provides a virtual environment into which you install windows (this was all very easy to do, trust me).  Gnome installed easily as it would into any windows environment.  Oh, and it works.  No need to boot into windows, you simply open VMware and start a windows session.  You have access to both the Lion and Windows OS and desktops!
The timing was good:  a new iMac with Lion + version 4 of VMware + windows 7.  Since I hadn't installed bootcamp yet, I didn't bother.  No need with VMware (although it can work with bootcamp if you have that installed already).
Very cool stuff,
Phil
SHV
« Reply #181 on: 1 Oct 2011, 04:58 am »
Having used both fusion and bootcamp, my advise is to avoid the pain of bootcamp and just use VMWare.
chuckworkb
Re: BDP-1 Recommended Interfaces - I need some help with Gnome
« Reply #182 on: 2 Oct 2011, 12:59 pm »
I am trying to figure out how to install Gnome on my windows laptop. There seem to be different sites with different versions, etc. Can someone point me to a link where I can get this and maybe some pointers on installing it. Thanks for your help!
chuckworkb
« Reply #183 on: 2 Oct 2011, 07:10 pm »
I figured out the install process for GNOME. Got it working, now the fun starts. Time to play some tunes! :green:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #184 on: 6 Oct 2011, 10:43 pm »
Alpha10
« Reply #185 on: 7 Oct 2011, 09:15 am »
Looking very good James. I have been using my laptop a little more to control the BDP lately, so this will be excellent.
Do you have an idea of when the next release will be? Or any other new features you might be adding?
Cheers
terrycym
« Reply #186 on: 7 Oct 2011, 09:21 am »
Looks great james.
Pass my praise the the software team.
How will it perform with an iPad?
Will it be able to handle rotating the iPad and re-rendering correctly to fit the display?
Max currently can't handle that very elegantly
What about scrolling within fields? That was an issue on Max for quite a while until resolved recently.
« Reply #187 on: 7 Oct 2011, 10:25 am »
Looks great james.
Hi Terry,
The demo I saw is on the iPad so that should work fine.
james
terrycym
« Reply #188 on: 7 Oct 2011, 10:41 am »
In which case I look forward to seeing it.
« Reply #189 on: 9 Oct 2011, 05:57 pm »
Hi Folks
I have purchased 2 Western Digital 1TB Passport drives in the last while and they are super with the BDP. I formatted them Fat32 and loaded 1 with FLAC and 1 with WAVE. They load fast and are dead quiet :thumb:
James
headshrinker2
« Reply #190 on: 10 Oct 2011, 05:57 pm »
Thanks James.  Why the larger drives?  Were you running out of room with your 500GB drives?  These WD Passport drives get their power through USB?
Hi Folks
James
« Reply #191 on: 10 Oct 2011, 06:19 pm »
Hi
Just for testing - wanted to try the larger drives for load time and also wanted to test FLAC vs Wave on the exact same drives with the same files.
James
headshrinker2
« Reply #192 on: 10 Oct 2011, 06:57 pm »
Any discernible differences between FLAC and WAVE?
Hi
James
« Reply #193 on: 10 Oct 2011, 08:10 pm »
Just setting up the blind listening today.
James
headshrinker2
« Reply #194 on: 10 Oct 2011, 09:54 pm »
Perhaps a fresh thread on this one?  Something that could (possibly) improve the audio should be interesting to many.  Also, wondering what other's on the forum who have done this comparison have found...
James
terrycym
« Reply #195 on: 11 Oct 2011, 09:29 am »
WAV will be like uncompressed FLAC soundwise
zybar
« Reply #196 on: 11 Oct 2011, 11:37 am »
I have done this comparison in the past and not heard a difference.  I have friends who do hear a difference.
Will try and run this comparison again sometime this week using hi-rez music.
George
« Reply #197 on: 18 Oct 2011, 02:38 pm »
Hi Folks,
New version of MPAD available.
james
zybar
« Reply #198 on: 18 Oct 2011, 03:06 pm »
Hi Folks,
james
Sweet!
Hopefully it has some of the improvements I asked Berrie for.
I'll download it tonight when I get home.
George
jjc1
« Reply #199 on: 18 Oct 2011, 04:25 pm »
Hi Folks,
james
  James, is this newer than last week? I just got my I Pad lastweek and downloaded the Mpad app then.I assume that's the new app?
