BDP-1/2 Recommended Interfaces
skunark
Re: BDP-1 Recommended Interfaces
« Reply #120 on: 10 Jul 2011, 07:14 am »
Thanks for the tip. The only reason I shy away from Apple products is because they become obsolete about every year.
John
I keep my laptop and desktops for several years then give it away to family or friends and they use it for several more.    Both the iPad and iPad 2 are fully supported and the iPhone, iPod Touch and most likely the iPad will continue with a three generation iOS updates, but older versions will still be supported for years to come just no new features.    Every major electronics company releases new products on a very fast cadence, but that does mean the old is useless.   If you are one to always upgrade, then that's your fault.
SHV
« Reply #121 on: 10 Jul 2011, 01:59 pm »
"Thanks for the tip. The only reason I shy away from Apple products is because they become obsolete about every year. "
My Mac Pro is five years old and I feel no need to replace it.  I have upgraded to 24 gigs of RAM and added faster HDs over the years but functionally it isn't obsolete.  Same with my Mac Book.
jjc1
« Reply #122 on: 11 Jul 2011, 02:07 pm »
  I'm referring to IPods, IPads, etc.
terrycym
« Reply #123 on: 11 Jul 2011, 02:10 pm »
I have one of the original iPADS and I don't believe it's obsolete unless I'm missing something?
I can still do all the things I bought it for.
BrysTony
« Reply #124 on: 11 Jul 2011, 02:30 pm »
When Apple makes changes and releases the "latest" product version it is the same as a Toyota releasing the new 2012 Camry.  It in no way makes the 2011 model obsolete.  It is more about marketing than function.
Tony
jjc1
« Reply #125 on: 11 Jul 2011, 04:09 pm »
Tony
O.K.  I defer to all you apple lovers. (All I know is that my daughter spends a fortune on every new I Phone that comes out, and she's not a teeny bopper)
BrysTony
« Reply #126 on: 11 Jul 2011, 04:13 pm »
 :lol:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #127 on: 14 Jul 2011, 04:57 pm »
New Android based interface that works well with BDP-1 Digital Player:
ARCHOS 70i using MPDROID
http://www.archos.com/products/ta/archos_70it/index.html?country=us&lang=en
james
Vipers
« Reply #128 on: 17 Jul 2011, 12:16 pm »
OK, I give up, I've been trying to log my Galaxy S2 into the BDP-1 using MpDroid but I keep getting a 'connection failed mesage', I guess I'm doing something wrong, any ideas?
All suggestions welcome  :?
Alpha10
« Reply #129 on: 17 Jul 2011, 01:55 pm »
Hiya, have you tried putting in the IP address rather than bryston-bdp-1.local?
Cheers
« Reply #130 on: 17 Jul 2011, 03:28 pm »
Correct as above - Android needs the IP address of the BDP-1.
james
Vipers
« Reply #131 on: 17 Jul 2011, 05:19 pm »
Thanks James, Alpha, I'll give it a try later this evening.
I take it the same applies for accessing Mini? as being an Android device, when I put the normal Bryston-BDP-1.local line in it does a google search which isn't a lot of help.
Yes the same for Mini. Also try PMIX as a MPD player app :thumb:
James
« Last Edit: 17 Jul 2011, 05:32 pm by James Tanner »
Vipers
« Reply #132 on: 17 Jul 2011, 08:54 pm »
That done the trick, thanks  :thumb:
Unless I'm doing something wrong, again :oops:, with MpDroid I could only seem to select one song at a time and not add whole albums in one go.
Good to have a play though, one thing I noticed was though how much quicker Mini is with the Galaxy S2 compared to my 2nd gen iPhone + the awesome screen on the S2 makes Mini look like it's had a makeover :)
Ok, time to try PMIX, thanks James.
« Reply #133 on: 17 Jul 2011, 09:19 pm »
On MPDROID touch and hold the album and it will pop up a window giving you options to play the whole album.
james
Vipers
« Reply #134 on: 18 Jul 2011, 11:54 am »
Thanks again James, it's good fun playing with all these different interfaces but Mpad really does take some beating doesn't it?
Well, aswell as Max and Mini of course :)
« Reply #135 on: 18 Jul 2011, 12:00 pm »
Yes mPad is a hard act tp follow - I think more programs will become available as Android operating systems become more popular.
James
Vipers
« Reply #136 on: 18 Jul 2011, 09:35 pm »
James
I think you're right James and that may be happening quicker than any of us thought possible against the might of Apple, this is a snippet from a report on What Hi Fi's website today -
'Google Android has seen its share of the UK smartphone market explode from 10.7% in June 2011 to 45.2% in June 2011, pushing Apple's iPhone down from 30.6% to 18.3% during the same period.'
The times they are a changin' :)
terrycym
« Reply #137 on: 20 Jul 2011, 01:22 pm »
Talking of Android...
http://www.whathifi.com/news/asda-prescribes-arnova-tablet-for-%C2%A399
jjc1
« Reply #138 on: 23 Jul 2011, 05:16 pm »
Yes I like it too and its great on a Notepad Computer :thumb:.  GNOME does not need a browser to connect so you get a direct connection to the BDP1 and GNOME is the oldest Linux based music player out there.
james
Hi out there. For the last week, I have been having a problem connecting to Gnome. I keep getting a notice "Error 13, problems connecting to bryston-'.bdp-1.local on port 6600". The connection icon just keeps flashing but never connects.
Is anyone else having this problem?
James, do you have any insight to this problem. I am not having any problems with Max, Minion or Mpod.
« Reply #139 on: 23 Jul 2011, 06:56 pm »
Hi - I have not had any problems - you can try the IP address of the BDP-1 and see if that works. Replace bryston-bdp-1.local with the IP address.
james
