0 Members and 2 Guests are viewing this topic. Read 439995 times.
the earliest version of Telefunken el84, logo print in negative, ceramic base and no diammond bottom
ok, no one knows these are rft made in the early 80's rebranded Telefunken?
Well, maybe the factory engineer could explain this, if he is alive yet.
I hope someday one of those man could iluminate all of us about hundred questions, a lot of tube wisdom and knoweledge will dissapear
I just though it's bizarre,why ribbed plate and that hole looks like philips (valvo or siemens) el84. any way I have no idea
Look how the mica was cutted, only rft made like that
ECC82
how did they sounds?
here comes another bizarre telefunken ecc82,has <> on bottom but mullard print and similer to philips code. K61 ⊥5C . 1955's?
I'm interested too, specially compared with "modern" ecc82 and other 50's philips factories ecc82
I afraid it already happen at least with the 300B. WE already dont know how to made a 300B sound good as in the past.I suspect there are various details in the making of the 300B that arent in the manuals of the factory.These important details were known only by the technicians who worked with this valve.So 300B lovers should forget this tube, the new 300Bs never will sound as the the Vintage 300B.
Only one word to describe the sound ( Turbo Charge ) think about all frequency gone up and more weight and body,powerful bass,your amplifier's output has been increase, sounds nothing like a Telefunken ( that's the reason I like them ) these are the only two Telefunken valves I will happy to use in my system. The other is ECC81 ceramic base.
they still didn't break up with siemens yet in those years,maybe some of siemens's technique
As far as I know Telefunken was the top brand in tube desing and development in 30's 40's and early 50's, at least in Germany, look at their power triodes made in the early 30's.... also I think Siemens started to do ecc8x under philips control in 1954, I bet you'll never see a siemens ecc8x earlier than 54...My thoughs about why hese early 1950-53 tele ecc8x sound different are concerning about some other construction and materials than later ones, or better production quality control... again we need an old Telefunken technician to ask...
Absolutely right,different construction effect the sound most,these Telefunken not only different to their own products but also unlike like any other valves, big silver pins, ceramic base wrinkle glass ( not whole glass )D getter. fantastic.
