Let's see your tubes!
adrianc
Re: Let's see your tubes!
« Reply #900 on: 22 Apr 2014, 04:42 pm »
Different versions of Hamburg made Valvo ecc83 through years:
From left to right: november 1954,  D getter with foil strip, copper rods, small hole on side--- july 1955, D getter with bigger foil strip one point welded, nickel rods, bigger hole on plate sides--- march 1956, same as 1955 but large rectangular folded getter and larger bottle--- june 1957, same features but  45ยบ big O getter.
I know there is also a first version made in late 1953 early 1954 with no foil on D getter and also a last made 1958-59 with smaller o getter.
greetings
shoot
« Reply #901 on: 22 Apr 2014, 05:10 pm »
Any body knows what is this valves??
VALVO 6211 made by philips heerlen factory. :green:
adrianc
« Reply #902 on: 22 Apr 2014, 05:26 pm »
These valves comes with 600 Telefunken ECC802s in a big bag which I bought long time ago.
shoot
« Reply #903 on: 22 Apr 2014, 05:28 pm »
:green:
adrianc
« Reply #904 on: 22 Apr 2014, 05:29 pm »
These 6211 gold pins comes with holes on plate
shoot
« Reply #905 on: 22 Apr 2014, 05:31 pm »
have <> on bottom?
adrianc
« Reply #906 on: 22 Apr 2014, 05:36 pm »
have <> on bottom?
Yes, Diamond mark on bottom
shoot
« Reply #907 on: 22 Apr 2014, 05:38 pm »
shoot
« Reply #908 on: 22 Apr 2014, 05:41 pm »
the earliest ecc82 I met,made in 1949.tung-sul black plates smoke bottle.most are grey plates.
adrianc
« Reply #909 on: 22 Apr 2014, 05:45 pm »
I have two version  ECC802  one with full strip the other half strip
shoot
« Reply #910 on: 22 Apr 2014, 05:52 pm »
full strip is not 6211?
I once saw a early version ecc802s looks like a ribbed plates telefunken ecc82,but was 19mm long plates.
adrianc
« Reply #911 on: 22 Apr 2014, 05:54 pm »
Does it sound bright and fast,I beg you don't like it :lol: :lol:
shoot
« Reply #912 on: 22 Apr 2014, 05:57 pm »
I like gray plates version more. :D
adrianc
« Reply #913 on: 22 Apr 2014, 05:58 pm »
Your 6211 are full strip??
shoot
« Reply #914 on: 22 Apr 2014, 06:01 pm »
Yes B329 made by Brimar
gray plates brimar 12AU7
shoot
« Reply #915 on: 22 Apr 2014, 06:02 pm »
telefunken 6211 is full strip. valvo 6211 are half strip
adrianc
« Reply #916 on: 22 Apr 2014, 06:08 pm »
Never interesting gray plate Brimar,only their Black Plate 82, 83, are top sounding valves :duh:
shoot
« Reply #917 on: 22 Apr 2014, 06:18 pm »
sounds not bad but can't compare with black plates one.
rodama
« Reply #918 on: 22 Apr 2014, 07:25 pm »
The best Brimar ecc82 I've heard, CV491 3rd week of may 1953
« Last Edit: 22 Apr 2014, 09:00 pm by rodama »
rodama
« Reply #919 on: 22 Apr 2014, 07:29 pm »
Does it have the Hamburg plant codes? looks like Heerlen/Copenhagen made...
