Let's see your tubes!
0 Members and 2 Guests are viewing this topic. Read 439209 times.
adrianc
Re: Let's see your tubes!
« Reply #720 on: 21 Jan 2014, 06:41 pm »
Sorry,should be Numbers Date Code
here are some 1552 G4s
shoot
« Reply #721 on: 22 Jan 2014, 02:47 am »
those tubes made in 1954,one of great sounding ecc81.I have 1 pair.
adrianc
« Reply #722 on: 22 Jan 2014, 01:25 pm »
shoot,have you listen to the R650 R6J Version (posted 266) to me these are the best sounding ECC81 when compared to my ECC81 stock.
shoot
« Reply #723 on: 22 Jan 2014, 02:24 pm »
I only have 650 R7B,It sounds great.I think yours R6J must be even better.
adrianc
« Reply #724 on: 22 Jan 2014, 03:33 pm »
More Mullard ECC81 declined square getter but with two holes on plate
adrianc
« Reply #725 on: 22 Jan 2014, 04:03 pm »
Marconi square getter
shoot
« Reply #726 on: 22 Jan 2014, 04:43 pm »
the right one are very rare,amazing  :o
adrianc
« Reply #727 on: 23 Jan 2014, 01:22 pm »
Yes the R6J Sounds much better,more R6J
The R7B round getter version
shoot
« Reply #728 on: 23 Jan 2014, 03:00 pm »
I know why i couldn't find R6J now.They all went to your warehouse :green:
shoot
« Reply #729 on: 23 Jan 2014, 03:05 pm »
VALVO 6201 made in 1957.D getter golden feet  pinched waist 3 mica.
shoot
« Reply #730 on: 23 Jan 2014, 03:21 pm »
lorenz ecc81.here is 2 version,D foil getter and round getter.there's another early square getter version i don't have.
shoot
« Reply #731 on: 25 Jan 2014, 04:30 pm »
PHILIPS Copenhagen factory made ECC81.
I have 3 version.from left,welded plates 1 bar D getter.1 hole no bar d getter,1 hole 2 bar d getter.don't know is there any other version.
rodama
« Reply #732 on: 1 Feb 2014, 12:34 pm »
Hello everybody, I have been follow this thread with great interest... some awesome collection of tubes!
First my rarest piece.... Valvo Hamburg 6067/ecc82, never seen before a picture of it, I cannot figure how many of these were made...
I think this is the only tube in the ecc82/12au7 family with the typical construction of e88cc or telefunken ecc803s
kind regards
rodama
« Reply #733 on: 2 Feb 2014, 02:25 pm »
Different versions of Hamburg made Valvo ecc83 through years:
From left to right: november 1954,  D getter with foil strip, copper rods, small hole on side--- july 1955, D getter with bigger foil strip one point welded, nickel rods, bigger hole on plate sides--- march 1956, same as 1955 but large rectangular folded getter and larger bottle--- june 1957, same features but  45º big O getter.
I know there is also a first version made in late 1953 early 1954 with no foil on D getter and also a last made 1958-59 with smaller o getter.
greetings
« Last Edit: 5 Feb 2014, 03:31 pm by rodama »
rodama
« Reply #734 on: 2 Feb 2014, 04:43 pm »
I think maybe 4 version. :D
The first version is the earlist which produced in 1952,No edges on mica,plate had one hole and one middle bar,black mercury,straight D getter.(the first one on the left)
Second version No edges on mica,plate had one hole and one middle bar,silver mercury,straight D getter.
third version Four edges on top mica,plate had one hole and one middle bar,straight D getter.
fourth version Four edges on top mica,plate had two holes and two bars,wing D getter.
What about this one? August 1952 Cleartop, bottom code YKB DZ
greetings
shoot
« Reply #735 on: 2 Feb 2014, 05:23 pm »
greetings
hello rodama.I never saw clear top versionbefore.does it still work well?
rodama
« Reply #736 on: 2 Feb 2014, 07:38 pm »
Hello Shoot, at first sight seems defective tube due to air inside causing mercury diluted, but it is working with strong emission and no gas, I think the coloration at top is due to hot getter .
I wonder if there is an even earlier  YKA version made in 1950-51... :)
Can I know the code of your darker mercury one?
« Last Edit: 4 Feb 2014, 04:54 am by rodama »
bladesmith
  • water quenching steel since 2001....
    • palmer knives
« Reply #737 on: 2 Feb 2014, 07:48 pm »
These sound freaking sweet. Very lush. But, not too smooth.
Very simple design.
rodama
« Reply #738 on: 2 Feb 2014, 08:08 pm »
Hello Bladesmith, never seen before rca's with that same mica as in 12au7 cleartops, very interesting tube :)
Guy 13
« Reply #739 on: 6 Feb 2014, 10:45 am »
Hi all Audio Circle members.
Those are the tubes that my wife’s nephew purchased for my birthday from TC Tubes USA according to my list and according to the recommendation from Ericus Rex.
Thanks Ericus Rex. :thumb:
Here they are from top to bottom.
Sovtek 5AR4 (NEW)
Raytheon 6080
Sylvania 12AX7
Raytheon 12AU7
Sylvania JAN 6922
Toshiba 6BQ5 (Pair)
8570
This one is for my soon to arrive Bottlehead Crack headphone amplifier.
This one is unbelievably inexpensive at 15 USD for such a BIG tube.
Made in USA.
8573
Of course it’s does not look new, even if it is,
as you can see from the bottom.
8576
Toshiba 6BQ5 to replace a pair of EL84 EH
for my Decware SE84C+
Each box had a little piece of Styrofoam to secure the tube.
Detail that I have not seen from Tube Depot, not to name it.
8578
Made un Japan.
8580
I was surprised to see that some of the pins were crocked.
At 24 USD each, I was expecting a little better.
I hope they will sound better than the EH they will replace.
8583
Sylvania JAN 6922 Made in USA for my Decware SE84C+
replacing a EH 6922.
8585
Raytheon 12AU7 Made in USA (Thomas organ) for my Bottlehead Crack.
8586
Sylvania 12AX7 (Long plates) Made in USA.
To replace my 12AX7 Ruby on my Bellari VP-129.
8587
All the pins on all the tubes did not look clean, therefore I tried to clean them with a tooth brush and some tooth paste, and I’ve been told that tooth paste is a little abrasive.
The results were far from being good.
Before
8589
After
8591
I don’t want to be pessimistic, but I hope that after replacing the stock tubes with the NOS tubes, I will hear a difference.
I will share with you my findings as soon as I have a minute to make the swap and sit down to do serious listening.
Guy 13
