Let's see your tubes!
adrianc
Re: Let's see your tubes!
« Reply #700 on: 20 Jan 2014, 05:16 pm »
I was confused before i got those tubes,why there's a additional getter supporter with no getter on it in telefunken ecc801s .after i got those early version ecc801s i came to understand that it's a evolution remains.just like human's caudal :lol:
Please post some of your valve collections,are you Chinese,if you don't mind I ask.
shoot
« Reply #701 on: 20 Jan 2014, 05:20 pm »
yes I'm a chinese,I admire your valve collection.It's really educated me.Learned a lot from you :lol:
adrianc
« Reply #702 on: 20 Jan 2014, 05:26 pm »
You shouldn't said that,you possibly had more valves than me.
shoot
« Reply #703 on: 20 Jan 2014, 05:29 pm »
Here is a very first version of valvo 6201 with declined square getter and  pinched waist,normal feet not golden feet.which was produced in 1956.
adrianc
« Reply #704 on: 20 Jan 2014, 05:36 pm »
I think I had a few of this version somewhere in the house.any way,some metal base
shoot
« Reply #705 on: 21 Jan 2014, 08:06 am »
those are closed getter? very rare.
adrianc
« Reply #706 on: 21 Jan 2014, 01:29 pm »
Rectangular getter,surprise.
adrianc
« Reply #707 on: 21 Jan 2014, 02:37 pm »
More metals
shoot
« Reply #708 on: 21 Jan 2014, 02:48 pm »
CV455(ECC81) welded paltes disc getter black mercury.produced in SEP.1951,by philips venolanda (holland) factory
philips miniwatt ECC81 welded paltes declined D getter .produced in DEC.1951,by philips venolanda (holland) factory
adrianc
« Reply #709 on: 21 Jan 2014, 04:14 pm »
Mullard welded plate ECC81
shoot
« Reply #710 on: 21 Jan 2014, 04:17 pm »
this is my first time to see mullard welded plate ecc81.Is it square getter?code number?
adrianc
« Reply #711 on: 21 Jan 2014, 04:17 pm »
Valvo ECC81 ECC81 declined getter
adrianc
« Reply #712 on: 21 Jan 2014, 04:24 pm »
Yes square getter,can not see the date code.
shoot
« Reply #713 on: 21 Jan 2014, 04:39 pm »
why do you judge it as mullard?
shoot
« Reply #714 on: 21 Jan 2014, 05:05 pm »
ok,I checked.it's made by mullard around 1956 :green:
adrianc
« Reply #715 on: 21 Jan 2014, 05:19 pm »
The top mica had more edges which  can be seen on older Mullard ECC81,82,the typical Mullard square getter and I'm not trust the printed.
shoot
« Reply #716 on: 21 Jan 2014, 05:32 pm »
Here is a picture from net(not mine).It has same inside stracture with yours.and it has a code R6D
adrianc
« Reply #717 on: 21 Jan 2014, 05:46 pm »
Well done shoot,I should have some Mullard ECC81 Date code 1552 J3 with two side holes but NO bar on plate
shoot
« Reply #718 on: 21 Jan 2014, 05:52 pm »
that seems to be the earlist mullard ecc81 made by mullard mitcham factory?I got only 1,code 1552 K3 :roll:  one kind of marconi b152 seems have same inside stracture with this kind mullard ecc81.
adrianc
« Reply #719 on: 21 Jan 2014, 06:14 pm »
Yes,this four letter Date code also appeared on ECC83 ( 1600 ) ECC82 (1593 )
I also had some 1552 G4 with one side hole no bar vertical support square getter
