Let's see your tubes!
aragon63
Re: Let's see your tubes!
« Reply #460 on: 25 May 2013, 03:02 am »
Jeff Larson's 6197 SEP / 2.7 watts , no neg. feedback & no caps in signal path ( two 6197 Amperex black plate pentodes & Mullard smoked glass 6CA4 rectifier )
ricko01
Bit of a Rogue
« Reply #461 on: 25 May 2013, 10:19 pm »
A combo of SS source's and preamp but underpinned by four Rogue M150 mono's. Photo isnt 100% current as I have changed my tonearm and 'table mat..but rest is current.
Tubes can be seen sexily peaking over the top
Used to use a Copland tube pre-amp but I went on a balanced/XLR kick, so it had to go.
Now I am fully balanced from  all source components to power amps including running my cartridge via a balanced cable.
Question: I havent strayed from using EH tubes with my Rogues... any suggestions regarding tube rolling?
« Reply #462 on: 25 May 2013, 10:26 pm »
Nice red stuff, what brand are these transformers?? Edcor?
Ericus Rex
Re: Bit of a Rogue
« Reply #463 on: 26 May 2013, 12:40 am »
Are you using EH KT88s or 90s?
aragon63
« Reply #464 on: 26 May 2013, 02:20 pm »
 Yes, Edcor's .
6197 pentode
6CL6 pentode
SET Man
« Reply #465 on: 26 May 2013, 11:24 pm »
Hey!
   Not mine, although I wish they were....
Kondo System by setpower1, on Flickr
    Kondo/Audio Note UK. From recent NY Audio Show. Beautiful in both looks and sound.
Take care,
Buddy :thumb:
adrianc
« Reply #466 on: 29 May 2013, 04:57 pm »
Mullard ECC35,Date code 1347 >>MS<<
« Reply #467 on: 29 May 2013, 06:18 pm »
Yes, Edcor's .
6197 pentode
6CL6 pentode
OK Thanks Bro.
Adrianc,
Your tube stock are endless. The date code is 1947, 13ª week??
A very old tube. I wonder how this senior tubes perform?? Any gas??
Ericus Rex
« Reply #468 on: 29 May 2013, 07:15 pm »
Any gas??
A rather personal question, don't you think?     :lol:
But seriously, I too am floored by your tube stash.  Thanks again for sharing.
adrianc
« Reply #469 on: 29 May 2013, 08:40 pm »
9
OK Thanks Bro.
Adrianc,
HI FULLRANGEMAN,these are very very old ECC35(Earliest type) and just working faultlessly,personally I like the second version(black plate with D getter) which I had 20 of them,the D getter sounds more open,lively and dynamic,and the Mid never sounds lean, The first version sounds more weight and a bit slow,it all depends what your system need.
Regards
Adrian
adrianc
« Reply #470 on: 29 May 2013, 08:42 pm »
Hi Ericus Rex,you are always welcome,take care
Adrian
TrungT
« Reply #471 on: 29 May 2013, 09:01 pm »
I think Adrain is Tube "HOARDER".
 :lol:  :thumb:
Very nice collections.
« Reply #472 on: 29 May 2013, 09:06 pm »
Regards
Adrian
Wow, It is always good receive a detailed lesson.
Thanks for sharing your expert advise.
Regards
adrianc
« Reply #473 on: 29 May 2013, 09:23 pm »
 :lol:  :thumb:
Thanks TrungT,you are right,I just collected old nice sounding valves as the earliest made always sounds better and that is the reason why I never use valves made after 1956. :)
« Reply #474 on: 30 May 2013, 09:40 pm »
Unfortunately this seems true, being mentioned only in the NOS WE300B x 300B new crop.
I think the secret in the NOS WE300B good sound is in the cathode wire metal formula or any procedure of making the metal wire.
Who made that cathode wire already died and the cathode wire formula registered in the books are incomplete or even may be an unknow treatment in the wire after the cast.
Who will discover it again?? WE failed in 1998 with that 300B release.
« Last Edit: 1 Jun 2013, 09:47 pm by FULLRANGEMAN »
adrianc
« Reply #475 on: 6 Jun 2013, 11:12 am »
Amperex E88cc pinched waist square getter.Date code 7LO 66C
Guy 13
« Reply #476 on: 6 Jun 2013, 11:20 am »
Hi all Audio Circle members.
Where do you guys get all those NOS tubes ? ? ?
Guy 13
dminches
« Reply #477 on: 7 Jun 2013, 01:09 pm »
Adrian should just change his name to "museum."
I always feel good about my tube collection when I have 1 or 2 of something that matches what Adrian posts!
adrianc
« Reply #478 on: 8 Jun 2013, 12:29 pm »
Hi David,moor E88cc for you
Amperex E88CC pinched waist rectangular getter with vertical support,date code 7L0 66F.
WireNut
« Reply #479 on: 8 Jun 2013, 08:52 pm »
All 6 of those you do me just fine  :green:
