0 Members and 1 Guest are viewing this topic. Read 439337 times.
Hi FM, not all of them are NOS (I wish they were) , NOS type 50 are very hard to find nowadays... The white numbers are just markings for measurement results, can be cleaned easily
Thanks for inform bro.
You're welcome my friend,more to come
Hi adrianc,Are those B65? They are very expensive to get nowadays, how do you like them compared to other 6SN7s? I've never listened to them and a bit hesitant to spend money to try as I would rather buy ECC32 Mullard brown base (I like the ECC32 the best amongst 6SN7s I've tried).Thanks,JPS: You've got amazing collection of tubes, respect!
to me,the best sounding 6SN7 is the STC later Brimar CV1988 which sounds beutiful balance from top to bottom,RegardsAdrian
Obviously everything is system dependent, but I found the CV1988s to be too lush. I was using them in a DAC along with a tubed amp. They just didn't seem to have enough drive and detail.Adrian, have you found a big difference in the various ECC32s? Any preferences?
Thanks Adrian. I will have to check mine to see which getters they have.What's your take on 6F8Gs? Any preferences?
I will let you know once I get the pair that I bought. I have heard good things about them.I take it you are located in Europe, or the UK specifically?
