Let's see your tubes!
adrianc
Re: Let's see your tubes!
« Reply #1120 on: 19 Jun 2014, 01:07 pm »
The bent mica points on the outer edge of the top mica are quite intentional and proper. They provide a tight fit for the mount (the stuff between the top and bottom mica) and the glass. If they weren't bent they might not touch and things would rattle around.
Also note the little raised hook on the top mica that holds down the cathode. That reduces microphonics. These tubes look perfect.
l don't think the shape of the getter makes any difference in the sound. The tube manufacturer just buys them from the getter guy. However it may help identify a particular vintage of manufacture as the getter guy does not always have the same stuff and sometimes he has new, better stuff.  From my studies it appears that D getters came before round "halo" getters which are an improvement as they distribute the getter material more uniformly. Perhaps that is why they were invented. Why D getters are preferred is a mystery to me. They don't do nearly as good a job as halo getters.
Hi Roger, I will be very surprise if you had compare  valves with different getter and found they sounds no difference,I wish my ears are the same as yours so I can have more time to do something else rather than searching valves :lol: :lol:
shoot
« Reply #1121 on: 19 Jun 2014, 02:27 pm »
 :green: :green:
adrianc
« Reply #1122 on: 22 Jun 2014, 02:24 pm »
 :lol: :lol: :lol:
shoot
« Reply #1123 on: 22 Jun 2014, 03:15 pm »
Adriano
« Reply #1124 on: 23 Jun 2014, 02:07 am »
adrianc
« Reply #1125 on: 7 Jul 2014, 11:27 am »
The most sought after ECC83 for audiophile.But not for me.
shoot
« Reply #1126 on: 7 Jul 2014, 05:14 pm »
yours are brimar? :thumb:
Adriano
« Reply #1127 on: 8 Jul 2014, 04:48 am »
My top 3 ecc83 is:
1.Mullard 1600 code long black welded plate square getter.
2.Philips long welded plate 45' D getter made in Copenhagen Denmark.
3.Philips long plate 45' D getter made in Heerlen  Holland.
adrianc
« Reply #1128 on: 8 Jul 2014, 04:28 pm »
My top 3 ecc83 is:
I'm using these ECC83 in my system,they all have their own strength and depends what amp using.No 100% winner
Adriano
« Reply #1129 on: 9 Jul 2014, 01:05 am »
From left to right
1 is Mullard 1960-1965 large ring getter
2 is 1955-1957 Philips long plate 45'D getter made in Heerlan Holand
3 is 1951-1954 Brimar long carbon black plate 45' square getter
Right?
« Last Edit: 9 Jul 2014, 02:39 am by Adriano »
shoot
« Reply #1130 on: 9 Jul 2014, 09:47 am »
that brimar ecc83 seems to be 1950's
adrianc
« Reply #1131 on: 9 Jul 2014, 10:44 am »
Yes and No
I'm using two Brimar in my Cat Ultimate and two Mullard B5B and one Bugleboy 12ax7 in the power amp
When using the Matisse I put two Mullard B5B and also two B5B and one Brimar ECC83 in the power amp
The Cat have a excellent sound stage and fast and powerful bass,with lot of low level details resolution  and excellent separation,tonal balance is a bit dry.
The Matisse sounds more round and forward,image is a bit large and less resolution even I substituted two Mullard f91 B7I which I think have the best low level detail of the Mullard square getter family.the best part of the Matisse is the mid range which sounds warm and relax and have more chest resonance,more like valve emotion
adrianc
« Reply #1132 on: 9 Jul 2014, 10:45 am »
From left to right
Right?
The Mullard is MC1 B5B square getter
shoot
« Reply #1133 on: 9 Jul 2014, 01:34 pm »
Yes and No
OK.consider your collection,you have countless combination choice :thumb:
adrianc
« Reply #1134 on: 9 Jul 2014, 05:15 pm »
Yes  :) that's why I need a lot of valves for
adrianc
« Reply #1135 on: 9 Jul 2014, 06:59 pm »
Mullard f91 B7I
adrianc
« Reply #1136 on: 11 Aug 2014, 04:05 pm »
PHILIPS Copenhagen ecc82
Yes,getting rare now.
Put these quad GEC in the Leak and sensed a burning smell  as the stickers and tubes are brand new and when the tubes gets hot and melt the stickers,shouldn't happen on used valves I think.
shoot
« Reply #1137 on: 12 Aug 2014, 03:13 am »
 :green: anyway you do't like them though it's very expensive now. :lol:
hiradi
  • in my 70th year and one windy ride !!!
« Reply #1138 on: 12 Aug 2014, 10:41 am »
Some great photos here, thought I add one of my old ones KR Audio Kronzilla in its first rack... :scratch:...some tube... :D...no glow...
Guy 13
« Reply #1139 on: 12 Aug 2014, 10:58 am »
Hi hiradi.
May an ignorant like me ask:
Other than more power,
what are the other advantages of using those monster tubes ???
...and for the same price, may I ask how much power you get from those tubes?
Are they SET ?
May I know, if not a military secret,
by how much one tube will make you poorer ?
Thanks in advance for your answers
and if you decide not to answer, thanks anyway for posting
those beautiful twin glass monsters.
Guy 13
I've seen quite of few of those tubes here on planet Vietnam.
The Vietnamese audiophile like those tubes, because it impress
the audiophile friends... :lol:
By the way, your rack must be under great stress with
that monster of amplifier on his back.
