0 Members and 1 Guest are viewing this topic. Read 440393 times.
It doesn't looks like a Siemens ?
The plate and getter are Phillips,but is a Siemens
Quite strange, the early Siemens Munich ecc8x have philips plate and/or getter, telefunken fat getter, valvo plates with side hole... frankenstein tubes
Even I never like Siemens valves but will love to try this 82,would it be a 83 version?.When I first got my welded plate D getter 82, I was wondering they should be a version with holes on plate,this Siemens tell me it do exist.
These two looks identical apart one of them without bars on plate,I don't know which one is earlier but guess the one with bars is the later version.
the first version of valvo 6201,made in 1956.three mica,square getter pinched weist.
First time I see this type, another museum tube if I see it well it habe an extra support but without getter??
1957,1958's D getter version also has an extra suppoter without getter on it.
it does not touch the square getter,kind like telefunken ecc801s's extra supporter.
I think the right one is early version,because not only with no bar,but also with an early version D getter ,the D getter is a little narrow and the wire is also alittle thick,it only appears in early version.
DEC,1951,made by philips venolanda S.A. D getter welded plates]this Mullard have the same welded plates but how can it was made in 1956 compare to 1951,five years welded plates still in production ? I doubt it.
Welded plates in 1956? quite strange, wrong codes?
