Servo Sub hookup
0 Members and 1 Guest are viewing this topic. Read 2029 times.
THROWBACK
Servo Sub hookup
« on: 5 Mar 2011, 07:41 pm »
(I posted this earlier on the OB Circle, and was advised that it might get a better response here)
Haaalllppp! I have put 2 SW-12-16FR Servo Subs into a single H-Frame cabinet on each side (for stereo) and I have made boxes for the two A370PEQ amps. The package came with a single wiring harness.
What it did NOT come with is a detailed diagram of how to hook up the speakers to the amps. I am also surprised that I have only one wiring harness. If that is for the stereo pair, seems to me I have to space the subs too close together.
Naturally, by the time I put everything together, it was Friday evening. Now there is noone around either Rythmik or GR Research to take my call.
A cry in the dark. Can anyone out there help meeeeeee??
Chuck Cabell
(719) 592-0472 (Colorado)
Danny Richie
Re: Servo Sub hookup
« Reply #1 on: 5 Mar 2011, 11:07 pm »
Done.
THROWBACK
« Reply #2 on: 6 Mar 2011, 05:17 am »
Danny was very responsive (Thanks, Danny). The answer was that one of the wiring harnesses was missing, and will be sent to me shortly. Whew! I thought maybe I was missing a few brain cells.
I still do have a question, however. I would like to do the one-woofer forward/one-woofer backward configuration to reduce 2nd harmonic distortion, but I'm not sure how to hook up the servo wires to the backard-facing woofer. The tab sliders are color-coded and sized for the correct tabs assuming a forward-facing woofer. I know I need to reverse polarity for the other woofer, but I'm not POSITIVE about what to do with the other woofer's servo wires.
BTW, I just ran a short test on one of the sets of woofers (both facing forward) and (so far) I am pretty impressed. All I did was play the right woofer channel by itself using the Stereophile Test CD 2 with the woofer decade, 200-20, and I got very clean-sounding output down to 20. I still need to check how they blend with my Sound Lab ESL's, how well they play symphonic music and how they do with transients. Stay tuned.
sl_1800
« Reply #3 on: 6 Mar 2011, 03:45 pm »
If Danny sends you the wiring harness I'm thinking of it will have all 4 voice coil wires and all 4 servo coil wires.
THROWBACK
« Reply #4 on: 6 Mar 2011, 05:48 pm »
Yes it will. The first one does.
Danny Richie
« Reply #5 on: 6 Mar 2011, 10:02 pm »
If you face one woofer another direction then you also have to flip the polarity on the driver and servo coil connections on that woofer.
THROWBACK
« Reply #6 on: 7 Mar 2011, 03:04 am »
That's what I thought, but I wanted to make sure.
Thanks.
