0 Members and 1 Guest are viewing this topic. Read 7959 times.
To cure the poor fidelity, I recommend the $15-20 Fiio e5 portable amp. Works a treat with my iTouch and my Shure iems.
I also use the Fiio E5 for anything I listen to from my ipod touch. I hope I didn't steer you wrong..... The Fiio really makes a difference, if you go that route get the cable that plugs right into the port used for charging, it will then bypass the internal sound card of the ipod all together..
