0 Members and 1 Guest are viewing this topic. Read 35760 times.
Guys if I have to because of cash reasons get an ipad 1 am I really making a dumb move? Is it like just wait ED until the cash is there its totally worth the wait or should I just get a first gen. The problem is typing on a regular keyboard is getting painful, even my SONY VAIO which has almost as nice a keyboard as my old Thinkpads can get to be rough. I'm no where near saying "screw it I can't type". But its definitely a future consideration, the neuropathy in my hands makes it painful to touch anything-unless its happening to you there is no way to verbally relay the feeling. I'm not bitchin, just thinking I got to do something in the next few months, maybe I just do a Gen 1 and smile about it...LOL. oops a small novelette!! sorry
Make sure you buy it new as the battery is not replaceable.
If I get one it will be from Apple- new or refurbed depending on the cash....I get a rent rebate check in July for $500 so I'll be ok...all I need is a 16 GB wifi and an AirStash (these look like nifty gadgets) then I'll have unlimited storage and can share files with my kids, friends etc...
Can any iOS4 or OS10 device be used as "remote" control of headless mini as music only server, either via ScreenShare, or numerous 3rd party software apps?
ok, then yes I saw a few apps for Mac that will do playback controls via itunes.
At an entry level pricing of (slightly) under half, what would the advantages of MBA over iPad as a third (second portable) device in a home system, that would probably never be used for anything other than browser and e-mail if it ever left the building?
The MBA does not have 3G or any sort of subscriber based internet access capabilities and as you said this is a huge plus in the iPads list of features.
The only ones I found so far are iTRC and TuneConnect. TuneConnect seems the best although it doesn't do artwork or have an album view. Which ones are you seeing?
My cable TV provider, Time Warner has an App for iPad that allows you to watch tv shows anywhere in the house. Now that is pretty cool!Can't wait for that new Zagg mate 2 and the new iPad 2 dock.
