BenF,
I too think that the XR50 is the successor to XR45. It is not just the weight, the digital inputs also can recognize 192Khz signals like the XR45. The XR25 did not have this feature.
One interesting and positive development is the THD has gone down.
It is .09% (versus .3%, almost 1/3rd of earlier value) between 20 - 20Khz. The power envelope is now rated at 4-88Khz at -3db. This rating was not provided with the earlier versions (Xr25/45). This means, that the new versions have a different chipset and the ratings probably came with the new chipsets incorporated in them.
Please note, that -3db at 4Khz is a very impressive figure. Many, even audiophile amps do not come this close. I am expecting the bass to be much tighter/extended).
One thing, I do not understand though is distortion is specified as .9% when the power envelope is specified (and it is same as in previous versions).
Beatles, how does the xr50 compare against the xr45 ? It is quite possible that the xr10 has better parts but probably not better specs/technology. Sometimes, better technology might not necessarily translate to better perceived sound. Still, the newer versions, I expect, would reasonably work well, across a broader range of speakers.
