Enclosure plans for N3S
0 Members and 1 Guest are viewing this topic. Read 5152 times.
jparkhur
Re: Enclosure plans for N3S
« Reply #20 on: 26 Apr 2011, 02:15 am »
Scuff it up, paint it flat black, 3dollars. Done
Danny Richie
« Reply #21 on: 26 Apr 2011, 12:58 pm »
No seriously, I hate that logo.
 It's very jarring and cheapens the look of the N3.  I'm thinking about cutting out some electrical tape to cover it if I have to. Can I order the N3 kit without the BG logo?
Just take a little B-12 Chemtool on a rag and wipe it off. You can also repaint the face plate with a flat Black spray paint to match the color of the woofer frame.
Rclark
« Reply #22 on: 26 Apr 2011, 07:57 pm »
You know, I'm wondering if it could work to paint all three faceplates something other than black.
Ron
« Reply #23 on: 26 Apr 2011, 08:28 pm »
 Painting the faceplates a different color is a neat idea. Since the faceplates are plastic Krylon Fusion spray paint would work well. Also, they have some cool colors to choose from too.
Danny Richie
« Reply #24 on: 26 Apr 2011, 08:39 pm »
Just be sure you guys wipe the logo off first or you will see it through the paint.
