You can never have too many tubes in the system...adding the Atma-Sphere MP-1
0 Members and 1 Guest are viewing this topic. Read 13870 times.
TomS
Mine has an "Invert/Normal" switch, though I'm not sure how that is implemented circuit wise. I don't have a remote but I think it just has volume up and down.
zybar
Do the AtmaSphere preamps have an absolute phase toggle control, either on the preamp or via remote?  I find this indispensable in my system.  Thanks
As Tom mentioned, the preamp has a switch on the front panel where you can invert phase.  The remote does not have this option.
George
Russell Dawkins
Too bad - the remote is where it's really useful!
roscoeiii
At least a remote is finally an option on Atma pres....
zybar
I had this feature on the remote of my Parasound JC-2 preamp and frankly, I never used it.
For me, it's a non-issue.
George
jtwrace
    • TIPP YouTube Channel
I'm a bit surprised that one would need that.   :scratch:
TomS
George
I never used it on my Bryston BP26 remote either.
