Is it normal for Mac Mini...
0 Members and 1 Guest are viewing this topic. Read 2723 times.
Dracule1
« on: 20 Feb 2011, 10:12 pm »
vibrate and make noise while importing a CD?  I'm not talking about little whining noise.  Mine vibrates enough to make my rack vibrate in sympathy and enough noise I can hear it clear across the room (22 feet).  A friend of mine said it's not normal.  It seems to work fine though.
xr2
Re: Is it normal for Mac Mini...
« Reply #1 on: 20 Feb 2011, 10:19 pm »
Doesn't sound normal to me.  My laptop sounded like that when I got it.  I took it in and they replaced the optical drive for me.
timind
  • permanent vacation
« Reply #2 on: 20 Feb 2011, 10:48 pm »
Is this happening with every cd?
My Mac Mini and also my laptop will do this with some cds, maybe one in twenty. I'd love to see someone chime in with a reason. I kinda figured it was an unbalanced disc but not sure.
rpf
« Reply #3 on: 21 Feb 2011, 12:37 am »
Mine does it too, periodically.   :evil:
One in about 20 sounds right.
Nels Ferre
« Reply #4 on: 21 Feb 2011, 01:54 am »
Mine  is horribly loud while burning a CD. This may be brand dependent- I am not sure as I have only one brand of blanks here. My MacBook is quiet with the same brand.
Mine is fine so far importing CDs or playing DVDs.  In any event, I will be taking mine to the Genius Bar at the Apple Store just to be sure, as it is under warranty.
timind
« Reply #5 on: 21 Feb 2011, 01:56 am »
Let us know the outcome if you don't mind. Mine is still under warranty also.
rpf
« Reply #6 on: 21 Feb 2011, 02:05 am »
Yes, do. I brought mine in for a tutorial and to the Genius bar for another problem and when I mentioned this one, I was told that they had no idea what it was. And couldn't do anything unless I left it and the problem occurred while they had it. As I bought the 3 year warranty, I didn't leave it and am not too worried about it now.
Nels Ferre
« Reply #7 on: 21 Feb 2011, 02:07 am »
I will definitely update y'all on this but won't have time to take it over there until next weekend.
Dracule1
« Reply #8 on: 21 Feb 2011, 09:44 pm »
Mine does it more than 1 in 20.  More like 1 in 3 or 4.
Atlplasma
  • Just off the boat
« Reply #9 on: 21 Feb 2011, 09:54 pm »
I have never had this issue with either of Minis, but maybe my drives are in better shape. How much usage on your equipment? I was advised when gearing up to create my Mini music server to buy a low-cost external. I used one to import most of my CDs.
Dracule1
« Reply #10 on: 21 Feb 2011, 10:06 pm »
I bought mine back last November but only about a week ago I actually opened it up and set up my server.  The noise was the first thing I noticed when I imported my first CD into the Mini.
Nels Ferre
« Reply #11 on: 2 Mar 2011, 01:11 am »
The Apple Store deems my drive just fine. I am burning a few CDs now with the Mini. Some are silent, some aren't- I think the noise is disc related.
On the other hand, my MacBook is quiet all the time.
I'm not going to worry about it.
Nels Ferre
« Reply #12 on: 2 Mar 2011, 01:13 am »
Lots of use in the two months I have had it- both for listening to music and streaming HD video movies. The drive has had very little use (less than 10 CD's burned, 4-5 CDs imported and a few DVDs played.) It only makes noise when burning.
