They're here!
0 Members and 1 Guest are viewing this topic. Read 13716 times.
Nuance
Re: They're here!
« Reply #40 on: 2 Mar 2011, 06:57 pm »
Yeah, no rush buddy.  Take your time, listen with your OWN amp (once it returns), and then write the review.  The wait will be worth it, at least for me.
Saturn94
Re: They're here!
« Reply #41 on: 3 Mar 2011, 03:52 am »
I'm not sure how much difference I might hear between the amps since my amp, a Parasound Classic 5250, is from the same line as the loaner, a Parasound Classic 2125.  The primary differences between the two amps are the number of channels (mine is 5 channels and the loaner is 2 channels) and the power ratings (mine is 250 wpc @ 8 ohms and the loaner is 125 wpc @ 8 ohms).
That said, perhaps I'll take your advice and hold off until my amp is returned.
BTW, over the weekend while my system was silent I resorted to using a portable speaker system like this hooked up to a MP3 player. :cry:  I was really roughing it! :lol:
Saturn94
Re: They're here!
« Reply #42 on: 18 Mar 2011, 04:58 pm »
I got my amp back yesterday and it seems to be performing normally.  Hope to have the review up within a week. :thumb:
Nuance
Re: They're here!
« Reply #43 on: 18 Mar 2011, 10:36 pm »
^ Woohoo - that's great news.  Happy listening buddy.
Saturn94
Re: They're here!
« Reply #44 on: 5 Nov 2011, 02:02 pm »
Saturn,
I would not consider anyone cheap that spends the money (very well spent) for a pair HT2-TLs :D. I can not recommend the Harmony remote enough as it has made operating my multi component system with numerous inputs a breeze to operate. The Harmony does have a learning curve but once you get the hang of the program it is quite easy to setup.
Bill
I was recently given a used Harmony One remote, so I thought I would give it try.  It didn't come with software, but after a little searching I downloaded it from the Logitech site and spent some time last night programming it.
We'll see if this will replace my basket of remotes or if I just go back to using the old remotes like before. :wink:
