FS: Jolida 1501 Tube Hybrid Amplifier $450 SOLD!
0 Members and 1 Guest are viewing this topic. Read 2904 times.
strateahed
« on: 14 Feb 2011, 06:59 pm »
SOLD!
I am selling a nearly brand new Jolida JD-1501P power amplifier. It was only taken out of the box for inspection and testing. It sounded very good right out of the box, and has less than one (1) hour of run time. This new hybrid amp uses a 12AX7 tube input stage coupled to a solid state MOSFET output stage. It produces 100 watts into 8 ohms and 200 watts into 4 ohms. The amp has both balanced XLR and single ended RCA inputs.
This is basically the same amp as the JD-1501RC tube integrated (retails for $825). I have owned amps from Outlaw Audio, Bel Canto, Wyred 4 Sound, and Channel Island. Also auditioned Nuforce. This amp is only slightly below CI Audio D200's and Nufore, but holds its own against other brands. So the 1501 series punches well above its price point. With adequate break-in, along with some nice 12AX7's like Shuguang Pavane Reference or perhaps some GE 5751 black / gray plates, this amp would easily compete with anything in the $1,000-$1,500 range IMHO. Invest another $500 or so in mods (recommendation available) and you've got a stellar performer.
According to Walter @ Underwood HiFi: “Sonics are excellent and competitive with amps selling for up to $1500.00. It is dynamic as well as detailed with a nice tube liquidity in the midrange.”
SPECIFICATIONS
Rated Output Power:
100 Watts per channel at 8 ohms, 22Hz to 19KHz
200 Watts per channel at 4 ohms, 22Hz to 19KHz
Frequency Response: (1 watt @ 8 ohms) 5Hz-100KHz + 1dB
Bandwidth: 22Hz to 19kHz + 3dB; 0dB 100 W 1KHz
Distortion THD: Less than 0.1% at 90 W output, 22Hz-18KHz
Input Impedance: 47Kohms
Input Sensitivity: 1.2V at 1KHz and 8 ohms for 100 watt output w/RCA, 2.4 volts with XLR inputs
Noise and Hum: 90dB below rated output
Tube Complement: Two 12AX7
Dimensions: 17" wide x 13" deep x 4.5" high high.
Weight: 32 pounds net, approx 35 pounds packaged.
Asking price of $450 includes PayPal fee and FREE UPS shipping in the lower 48 States. PLUS buyer will receive another very valuable bonus with this sale. PM me for details. Check my feedback on AudiogoN and on Ebay (same user name) and buy with confidence.
« Last Edit: 15 Feb 2011, 09:41 pm by strateahed »
