Wired Transporter/SB3 Network Test Throughput?
0 Members and 1 Guest are viewing this topic. Read 888 times.
vett93
« on: 12 Feb 2011, 05:14 pm »
What throughput do you get when you do Network Test on Transporter or SB3? When I did Network Test on Transporter, two things puzzled me:
1. It started with 64Kbps and I got 100%, which meant no packet loss. It stayed at 100% as I increased the bit rates until it hit 2 Mbps. There was at least 50% packet loss at 2Mbps. So I backed off the bit rates. But it also had high loss at 1.5Mbps and 1Mbps. It went back 100% when the bit rate was 500Kbps. Then I increased the bit rates again and got 100% for 1Mbps and 1.5Mbps.
My first question is why 1Mbps and 1.5Mbps had different behaviors? When I went from 500Kbps to 1Mbps and 1.5Mbps, it had no packet loss. But when I went down from 2Mbps to 1.5Mbps and 1Mbps, it had a lot of packet loss.
2. I got more than 50% packet loss at 2Mbps. Is this normal? This seemed very low throughput to me.
3. What throughput levels do you get with your setup?
Thanks a lot.
