0 Members and 2 Guests are viewing this topic. Read 63722 times.
Hi Greg,Wendell's response - "Bass driver magnet and the perforated steel pole piece have a slight curvature by design to allow for the travel of the diaphragm."Wendell
Looks like they're very close to the back wall. Is this really where you put them?
Hi Bill,I have the 1.7's but the not he 3.7's yet (on order) - I think you have to know someone high up at Magnepan to get a priority placement james
why is the "Magnepan Chat Room" placed here under bryston instead of under the planer circle or a new circle.do you guys have some kind of financial arrangement between you?
Thanks for taking on this load James.Re: pole piece curvature - when and how is the curvature formed in the manufacturing process? Is the curvature constant from top to bottom of a panel, and is the tension on the mylar the same from top to bottom?Thanks!
Hi CalypteIn the small room (16x12) they are about 2.5 feet from the back wall - long wall - in the larger room (23x17) they are about 4 feet from the back wall - short wall...
Thanks to Jams and Wendell for this opportunity! Does a push-pull configuration like 20.x have a single mylar layer?Thanks
Thanks. I was sure the placement was carefully considered, and I was just interested in hearing some discussion about it. I live in a Calif. suburban home, and they rarely provide the idealized shoebox-shaped rooms for audio & HT so beloved by "how to place your speakers" articles in magazines, so I have to work with what is available. The manager of my living quarters (i.e. wife of 44 yrs) has been tolerant of whatever I wanted to do with speakers or anything else, but she surprisingly objected to a radical rearrangement of the living room where the Maggies are located, so I have to work with what's available. They sound great most of the time, but sometimes a resonance in the deep base gets energized, and I'd like to mitigate that. Magneplanar 1.6 QRs don't do 20 Hz organ pedals, but bass drum and low piano and bass viol can be surpisingly potent.
Are 20.7s in the works ? charles
