A request for Danny - LS Center Channel Kit
0 Members and 1 Guest are viewing this topic. Read 87307 times.
Outofthewoods
  • Fallen Enclosures, Inc. Crafted with Passion
Re: A request for Danny - LS Center Channel Kit
« Reply #60 on: 13 Feb 2011, 08:22 am »
Yes!!! FINALLY an LS Center!! WOOHOO!!
Hi Eric,
It's been a long time coming, hasn't it? :D
Will these be available only in kit form? Or will buying a ready built (plug & play) speaker be an option??
See reply #31 on page 2 of this thread. :thumb:
Ruben
Nick77
« Reply #61 on: 13 Feb 2011, 12:13 pm »
Danny i have been assuming that this will also be the perfect speaker for the OB/7. Am i correct?
Danny Richie
« Reply #62 on: 14 Feb 2011, 02:52 am »
Really? I might be interested if the price is right.
How about $35 each?
I have to stick with selling them only as kits so I don't compete with any of the companies that I do design work for.
But I think Ruben will accommodate you your assembly needs.
Yes, it would.
edoggrc51
« Reply #63 on: 14 Feb 2011, 04:44 am »
Hi Eric,
Ruben
Definitely has brotha! Just glad its finally becoming a reality.  :green:
edoggrc51
« Reply #64 on: 14 Feb 2011, 04:46 am »
That'll work too!  :thumb:
Thanks Danny!  :D
Outofthewoods
« Reply #65 on: 14 Feb 2011, 04:51 am »
Yes, it would.
Given proper clearance, the modified OB-7 Plus would be the "ideal" OB-7 CC, wouldn't it?
Assuming a rear ported LS Center, what would you recommend as the optimal distance from the wall behind?
If there wasn't the option of pulling the CC out into the room and it had to be placed within a few inches of the wall behind, would you recommend the N3S as a viable alternative for the OB-7's?
Ruben
edoggrc51
« Reply #66 on: 14 Feb 2011, 05:05 am »
 :notworthy:    :drool:    :rock:    :dance:
skeeter99
« Reply #67 on: 14 Feb 2011, 05:23 am »
Given proper clearance, the modified OB-7 would be the "ideal" OB-7 CC, wouldn't it?
Ruben
Is this the box for the new center? Is it going to be OB for the center drivers? Looks like a giant X-Voce ...
Outofthewoods
« Reply #68 on: 14 Feb 2011, 05:34 am »
No, that's the OB-7 Plus, Minus the Plus. :green:
It's known as the "OB-7 Center".
I posted it in response to Danny's answer to Nick about pairing the LS Center with OB-7's.
Sorry for the confusion.
Ruben
skeeter99
« Reply #69 on: 14 Feb 2011, 05:40 am »
Ruben
Ahh got ya! I was getting really excited to have a new bigger/badder X-Voce! Still interested in this though :)
Outofthewoods
« Reply #70 on: 14 Feb 2011, 05:45 am »
Actually Scott, that IS a bigger/badder version of the X-Voce! But instead of the Encore tweeter, it uses the BG Neo3. :thumb:
Here's the OB-7 Plus product page.
http://www.gr-research.com/index.asp?PageAction=VIEWPROD&ProdID=121
Delete the subwoofer section and you get the "OB-7 Center."
Ruben
Danny Richie
« Reply #71 on: 14 Feb 2011, 06:18 am »
If you have OB-7's as left and right mains, and you have room to pull the center channel a good distance out from the wall then this version of the OB-7 would be really ideal.
skeeter99
« Reply #72 on: 14 Feb 2011, 02:42 pm »
My Voce isn't really far out but still a decent amount. I've found the back reflection to be extremely spot on for imaging with the center of my TV. I LOVE the OB sound so maybe an OB7-C would be a better match to my Mini's  :scratch:
rseynaev
« Reply #73 on: 15 Feb 2011, 03:55 pm »
The minute you responded with the idea of a new center I shot you an email offering to build the test enclosure. Check your email! :green:
As soon as I get the dimensions from Danny, I'll get started. :thumb:
Ruben
Have you started yet?  :icon_lol:
How does this work btw?  Does Danny send you detailed cabinet plans or just rough dimensions?
Randy
Beatcoaster
« Reply #74 on: 15 Feb 2011, 05:27 pm »
lol, ya chip chop you guys - it's already been a week, and I got money burning a hole in my pocket!  :icon_lol:
soundofrockets
« Reply #75 on: 15 Feb 2011, 09:03 pm »
glad to hear that some progress is made in this direction........i am currently using xvoce........with regards to the finish choices........i have that starry night black obsidian.........is this finish possible.......plus any possibility of matching stands to go with the beast ?
Danny Richie
« Reply #76 on: 15 Feb 2011, 09:04 pm »
Welcome to AC soundofrockets.
soundofrockets
« Reply #77 on: 15 Feb 2011, 09:19 pm »
thanks Danny.....i am big fan of your creations...........
Outofthewoods
« Reply #78 on: 15 Feb 2011, 09:23 pm »
Absolutely!
I have the better part of a gallon of that EXACT paint sitting in the shop. :thumb:
Yes, Sir. I already have some rough sketches drawn up.
Your LS-9's have the rectangle "floating" bases don't they?
Welcome to AC! :D
Ruben
soundofrockets
« Reply #79 on: 15 Feb 2011, 09:27 pm »
yes they do........but the 6s have the X base........just plain old piano black for the 6s
