As far a transfer efficiency, when I was ripping my CD collection, I might have 20-30 albums to be transferred at one sitting.. It was more time efficient to attach the BDP-1 drive directly to the USB port on my Mac than to transfer via wireless. Now that I just transfer a song or a few albums, I rarely do direct transfer.Steve
what about the Lacie device which seems functionally very similar: http://www.lacie.com/uk/products/product.htm?id=10491 ? I thought someone said that did work with the BDP-1? It boasts both ethernet and USB interfaces.
The USB port on the LaCie NAS is for direct connection to a computer (or the BDP-1) in lieu of the Ethernet network connection, they cannot be used simultaneously. Steve
Presumably it could simultanously be connected to a home network by ethernet and connected to the BDP-1 by USB, so that it could be used as a network server and principle data store whenever it was not being used to play files on the Bryston? I could live with that!
Steve, so where do you keep your music files? Do you have them only on USB thumb drives and external USB hard drives connected to the Bryston or do you have a back-up on your Mac as well?
From: Paul Sent: August-16-11 5:33 AMTo: Bryston - James TannerSubject: Bryston BDP-1, BDA-1The BDP-1 can read FAT32 or NTSF it was just it could not write to NTSF until recently – new softwarejames
James, re this new software, does this mean you can now write over the network to a HDD attached to the BDP-1 if the drive is formatted NTSF rather than FAT32?Nigel
I am using an iPod Touch/iPad and MacBook Pro for control of the BDP-1. I have a Harmony remote for the control of my other equipment. Does anyone know if the Harmony remotes can be used to control the BDP-1? I do not have Bryston's remote, so I would not be able to learn the commands from it, so I would have to rely on the Harmony database of commands. Thanks
Yes, the bdp-1 appears to be in the harmony database, but it does not seem to work. When I press the power button, the light on the bdp flickers as though it recognizes the signal, but it will not turn it on.
Hi Gilles,Yes you can connect a dedicated router to the BDP-1 and use any wireless device to connect to it - I call it my ManCave option.james
James,With this mancave option will you be able to upgrade the firmware wireless.Will it show up in your computer network?Or it's strictly just for the use of the interfaces with your wireless devices with the bdp-1?Will Mpod/Mpad work in this config or only Max/Mini only? What router are you using?
I have managed to set up my BDP-1 on my home network, my PC can see attached USB devices (the Bryston flash drive and my WD My Passport 1TB hard drive) and I am controlling everything wirelessly with a Sony S tablet (android). I can read and play flac files on my PC over the network from both devices when they are connected to the BDP-1, but when I try to drag and drop files from my PC to the Bryston over the network I can only write to the flash drive. When I try to write to the WD My Passport USB hard drive I am told I need permission, access denied. The Bryston settings page lists the drive under "writeable" as "no" whereas for the flash drive it says "yes". I have looked at the settings for the WD on my PC (properties-sharing and security) and it is set for sharing files and the box against "write" is ticked. Indeed I can write normally to the WD when it is directly attached to the PC but not when connected to the BDP-1 over the network. Any suggestions??
James, the drive is formatted NTSF.Nigel
Hi NigelNot sure what is happening - do you have another drive that you can format FAT32 and see if you can write to it? Most thumbdrives come FAT32. James
Yes, I can write over the network on to the Bryston thumb drive which came with the BDP-1 and is FAT32 fomatted. But I can't write to the NTFS formatted My Passport drive unless I plug it in directly to the PC. I don't have another external hard drive which I can reformat.On the Bryston settings page it says "README: *NTFS (Windows) volumes do not support Read/Write function currently; support is planned*After remotely copying files to a drive, click the 'Update' button above"Nigel
