BRYSTON BDP-1/2 FREQUENTLY ASKED QUESTIONS THREAD
0 Members and 15 Guests are viewing this topic. Read 1042511 times.
terrycym
Re: BRYSTON BDP-1 FREQUENTLY ASKED QUESTIONS THREAD
« Reply #480 on: 22 Nov 2011, 03:52 pm »
I woudn't pay too much attention to what reviewers say.
They're not listening to your system afterall.
Try both and stich with the one which sounds best to you.
I chose AES but that was my choice for my system which I'll bet is different to yours?
Bavarian05
« Reply #481 on: 22 Nov 2011, 04:04 pm »
Normally I would completely agree. I have ordered both the BDP-1 and BDA-1 without being able to hear either of them first as none of my local dealers are stocking or offering demo's on them. I have never done this before, but with Bryston, I am thinking it is a safe bet. I would rather avoid having to purchase both cables if I don't have to. Both cables would be considered special orders and I cannot return the one I don't like. I can always sell on Auduigon at a loss, but would like to avoid the trouble if possible. Please tell me what specifically you preferred about the AES/EBU over the BNC connection.
jjc1
« Reply #482 on: 22 Nov 2011, 04:13 pm »
For what it's worth, I spent a couple  of weeks with Kimber Select S/pdif and AES/EBU cables thru the BDA1 and BDP1. They are excellent cables. I found that the AES/EBU offered a fuller, more analog sound while the S/PDIF was a bit more detailed but a bit thinner sound. But as Terry said, it really will come down to one's preference.
  Hope this helps.
terrycym
« Reply #483 on: 22 Nov 2011, 04:27 pm »
AES sounded like music and BNC sounded like a recording.
This is somewhat exagerated as the differences were subtle.
There again, others heared it differently and prefer BNC.
A lot of dealers and on-line sellers do sale or return
I presume you're in the USA so try The Cable Company.
Bavarian05
« Reply #484 on: 22 Nov 2011, 04:32 pm »
That is helpful. Thank you.
Did you find a difference in imaging?
Sound staging depth and width as some reviewers have suggested?
As a point of reference, they will be run with an ARC LS17, Bryston 4B SST2 and Magnepan 1.7's.
Audioquest CV-8 speaker cable and Columbia balanced cables.
jjc1
« Reply #485 on: 22 Nov 2011, 04:38 pm »
Terry, if you order from The Cable Company, aren't you obligated to purchase some cable from them? I thought I once read this in their literature.
terrycym
« Reply #486 on: 22 Nov 2011, 04:42 pm »
Don't know mate.
Can you order one of each and return the one you don't like?
I like Pure Note cables and they do sale or return, no questions asked.
SHV
« Reply #487 on: 22 Nov 2011, 04:42 pm »
I can't hear any difference but if you want to test for your self, you can order high quality pro cables at a fair price.
example:
http://www.markertek.com/Cables/Audio-Cables/XLR-to-XLR-Cables/TecNec-Cables-Connectors/MSC1-5XXJ.xhtml?MSC15XXJ
http://www.markertek.com/Cables/Video-Cables/Video-Patch-Cables/Canare-Corporation-Of-America/VAC010F.xhtml
If you prefer one or the other,  then you can buy the boutique cable with the cryo treated quantum copper wire and the un-obtanium cosmic ray reflecting cover; for just a few thousand more.
jjc1
« Reply #488 on: 22 Nov 2011, 05:12 pm »
Don't know mate.
  Best to read the return policy before you order anything from The Cable Co.
SHV
« Reply #489 on: 22 Nov 2011, 06:08 pm »
Here is another custom cable site, I haven't used them but mark-up looks reasonable for the quality of components, especially if you want XHADOW connectors.
http://www.soundoctor.com/cables.htm
terrycym
« Reply #490 on: 22 Nov 2011, 06:34 pm »
Cables are like audiophiles' audiofools' jewelry  :lol:
jjc1
« Reply #491 on: 22 Nov 2011, 08:07 pm »
That's why the manufacturers name them after jewels...Diamond, Saphire..etc.,etc.
SHV
« Reply #492 on: 23 Nov 2011, 05:09 am »
Especially when you research the cost of the components that go into the kilo-buck cables and then calculate the mark-up...yikes.
terrycym
« Reply #493 on: 23 Nov 2011, 10:04 am »
Talking of which, have you seen inside a Naim external power supply and what they charge for them?
They're taking their customers for mugs!!!
saveloy
« Reply #494 on: 27 Nov 2011, 01:51 pm »
Thank you for the info.
Are you using the BNC or AES/EBU connection between them?
I see alot of conflicting opinion on this subject out there. The rest of my
system is running fully balanced, but reviewers seem to prefer the BNC connection.
I use the balanced connection.  Many reviewers like the BNC, but I really do like the sound a balanced connection provides.  Again, I think it's more accurate.
Kyri
bluemark81
« Reply #495 on: 27 Nov 2011, 02:48 pm »
Not sure if this is the best place to post this, but I will start here anyway.  I finally got my BDP-1 last week and got it all connected to my network.  I have it working fine using Bryston's Max interface.  The internet radio stations are great.
As an alternative to Max, I've added the Minion add-on to Firefox, but I can't seem to get it to work.  I've added the bdp-1 server as my host under manage servers, but it does not work at all.  I am using a macbook pro os 10.7.2 (lion).  I've also tried adding the ip of the bryston versus the path, but still nothing.  Does anyone have any suggestions other than just use Max?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #496 on: 27 Nov 2011, 03:13 pm »
Hi blue,
Minion seems to have a problem with the latest versions of Firefox.  It worked fine on previous versions.  I have a file that seems to work so email me at [email protected] and I will send it.  You just drag and drop it on top of Firefox.  seems to work for me and a number of others that have tried it.
james
alexone
« Reply #497 on: 28 Nov 2011, 10:36 am »
Hi blue,
james
James,
you mean that the file will work with the latest Firefox?
al.
« Reply #498 on: 28 Nov 2011, 11:35 am »
James,
al.
Hi al
Yes the fellow that created Minion says this file should work up to version 9.  I find it does on my MAC laptop and Windows 7.  Some say it does not.
james
Marius
« Reply #499 on: 28 Nov 2011, 02:43 pm »
Hi James,
I'd like to give it a go and mailed you just now.
Greetings!
Marius
Hi al
james
