BRYSTON BDP-1/2 FREQUENTLY ASKED QUESTIONS THREAD
0 Members and 16 Guests are viewing this topic. Read 1042500 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BRYSTON BDP-1 FREQUENTLY ASKED QUESTIONS THREAD
« Reply #460 on: 3 Nov 2011, 09:46 pm »
MPad seems to be a game controlling app of some sort at $.99.  Doesn't quite appear right to me, but perhaps it is.
Go to the APPs store and type in MPAD under search.
james
bluemark81
« Reply #461 on: 3 Nov 2011, 09:57 pm »
Not yet.  I just want to have everything setup and ready to go when it arrives.
« Reply #462 on: 3 Nov 2011, 10:07 pm »
OK you need the BDP in order to connect :thumb:
James
bluemark81
« Reply #463 on: 3 Nov 2011, 10:21 pm »
James
Ah.....ok.
bluemark81
« Reply #464 on: 3 Nov 2011, 10:22 pm »
I just found out that HD Tracks are only downloadable in the US.  That sucks!
Alpha10
« Reply #465 on: 3 Nov 2011, 10:28 pm »
No you can pay with paypal from anywhere, I am in the Uk and it is no problem.
bluemark81
« Reply #466 on: 3 Nov 2011, 10:57 pm »
ok, didn't try purchasing anything because I read that downloads are just for US customers.  Thats good to know.  I am in Canada.
SHV
« Reply #467 on: 4 Nov 2011, 12:39 am »
Here s another site:
http://www.channelclassics.com/
It's located in Holland but I have no problem downloading to USA.
alexone
« Reply #468 on: 4 Nov 2011, 05:59 pm »
hi, Bluemark!
...basically the BDP-1 is an "out-of-the-box-and-ready-to-play" unit so you don't really need to download (if any) software to play your files. furthermore the player has the Bryston Max (for computers) and Bryston Mini (for handheld devices), Gnome and Minion if you want to control the BDP-1 via your computer.
software updates are available and should be done, of course.
al.
terrycym
« Reply #469 on: 4 Nov 2011, 06:04 pm »
I managed very well for the 1st few weeks using just the front panel controls
bluemark81
« Reply #470 on: 4 Nov 2011, 06:56 pm »
Thanks guys.  I didn't want to get the unit only to find out I need to have a bunch of software and other things first. I guess I'm getting ahead of myself.
pardales
« Reply #471 on: 9 Nov 2011, 09:15 pm »
How does the BDP-1 handle internet radio? How would you look up and select stations, and play them?
JfTM
« Reply #472 on: 9 Nov 2011, 09:59 pm »
http://www.youtube.com/embed/NOggDwajyNs?hl=en&fs=1
pardales
« Reply #473 on: 9 Nov 2011, 11:56 pm »
Eeek! That's what I was afraid of. But thank you, this was informative.
SHV
« Reply #474 on: 10 Nov 2011, 12:28 am »
I think that I will stick to my Squeezebox Touch/BDA-1 combination for internet radio unless/until BDP-1 radio service becomes more user friendly.
« Reply #475 on: 10 Nov 2011, 12:54 am »
The BDP was never really designed for Internet radio so I would say definitely stick with the Touch or similar products if that is your main source of listening.
James
SHV
« Reply #476 on: 10 Nov 2011, 02:57 am »
"The BDP was never really designed for Internet radio"
Exactly...That's the nice thing about the BDA-1; with 8 inputs, I can hook up IPad/Pod dock, Apple TV, Touch, CD transport, BDP-1,  etc. and switch inputs with Logitech.  That said, 90% of time it's on AES/EBU BDP-1. :>)
Bavarian05
« Reply #477 on: 21 Nov 2011, 09:46 pm »
What length are the power cables supplied with the BDP-1 and BDA-1?
Any real benefit to upgrading from the supplied power cabling on either or both units?
saveloy
« Reply #478 on: 21 Nov 2011, 11:31 pm »
They are 1.5M each.  I have swapped both for aftermarket cables.  I find it gives a bit more in the way of clarity.
Kyri
Bavarian05
« Reply #479 on: 22 Nov 2011, 03:28 pm »
Thank you for the info.
Are you using the BNC or AES/EBU connection between them?
I see alot of conflicting opinion on this subject out there. The rest of my
system is running fully balanced, but reviewers seem to prefer the BNC connection.
