BRYSTON BDP-1/2 FREQUENTLY ASKED QUESTIONS THREAD
skunark
Re: BRYSTON BDP-1 FREQUENTLY ASKED QUESTIONS THREAD
« Reply #180 on: 22 Feb 2011, 01:37 am »
Hi Jim - - No advantage to upsampling in my opinion.  The only issue I have had with mp4a is lack of album art which i do not have with Flac.
james
You can add album art to the mp4a.  iTunes and other like players might optimize storing the artwork outside of the file to speed up scrolling through the albums.  For iTunes, all you need to do is "copy" the artwork and "paste" it back to the album, there's probably other applications that will do that as well
Aescalpius
« Reply #181 on: 22 Feb 2011, 02:25 am »
Hello all; I'm running a Mac Mini with an external HD feeding my DAC and I have a question regarding file management.  I usually back up my HD from the master iTunes file on my iMac over my home network using a program called ChronoSync which does this automatically on a daily basis, keeping both libraries in sync.  This is easily done over the network, without having to unplug the HD and then plug it into the iMac then back again.  Would I be able to do this with the HD plugged into the BDP-1?
Alternatively, if the HD is plugged into the BDP-1 and I plug a USB thumb drive onto another port, could I use the BDP-1 to transfer the files from the USB thumb drive to the attached HD?  Or, could I do this by accessing the BDP-1 over my home network and manually transfer the files?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #182 on: 22 Feb 2011, 11:49 am »
Hi,
 I am not sure on the sync function but you can transfer a file from any of the attached harddrives 'over the network' to any other attached drive as long as the drive is formatted FAT32.
james
« Reply #183 on: 22 Feb 2011, 06:47 pm »
As I do not have an iPad I was looking at a small (7") tablet PC with wifi, so I could use Mini, but most I have looked at run Android 1.6 and the user guide for the BDP-1 says Android 1.5 OR Android 2.2, does that mean these tablets will not work?
Cheers
Hi,
I spoke with our software engineer and Android 2.1 and up will work but we recommend using the Zirco Browser (available on Android market Place -http://market.android.com/search?q=zirco).
We are going to test the Samsung Galaxy Tablet as soon as I can get a hold of one.
james
Tested the Galaxy Tablet last night and it works with the Bryston Mini application - will do more tests.
james
« Last Edit: 23 Feb 2011, 12:23 pm by James Tanner »
skunark
« Reply #184 on: 22 Feb 2011, 09:47 pm »
james
Should be easy to find as they aren't flying off the shelves..
« Reply #185 on: 23 Feb 2011, 01:17 am »
Got one :D
james
Bugsy
« Reply #186 on: 23 Feb 2011, 08:55 am »
Here is a good read about Computer Audiophile Ripping Strategy and Methodology.
http://www.computeraudiophile.com/content/Computer-Audiophile-CD-Ripping-Strategy-and-Methodology
Larry
Welly123
« Reply #187 on: 23 Feb 2011, 12:42 pm »
Hi,
james
james
I have used Bryston Max and Mini successfully on three Android tablets (all ViewSonic) using the default browsers:
ViewPad7 - 7” running Froyo (2.2)
ViewPad10s - 10” running Froyo (2.2)
Viewpad10 - 10” (dualboot) running Donut (1.6) and Windows 7
All suffer the same issues of not scrolling down a playlist, but then this also occurs with most desktop browsers (I’m hoping this will be fixed in a future FW release but it’s not a big issue as there are alternatives). For the most part they run OK and certainly sufficiently well for basic control of the BDP-1.
Regards
Russell
« Reply #188 on: 23 Feb 2011, 12:55 pm »
Regards
Russell
Hi Russell,
I tried the Tablet last night and it worked well with Bryston Mini.  Are there any MPD Linux apps you know of that can run on Android operating system?
I downloaded Firefox for Android but it does not appear to be able to aquire Minion app.
james
« Reply #189 on: 23 Feb 2011, 05:35 pm »
Hi Folks,
Well the Samsung Galaxy Tablet works really well with the BDP-1 using MPDroid. Looks like the standard Android Music Player except controls MPD.
Log on to the internet and go to the 'MARKET' icon on the Galaxy Tablet desktop and download the 'MPDROID APP (its free) by searching 'MPD'
Works great. :thumb:
james
PS - currently need to put the IP Address in HOST (not- bryston-bdp-1.local)
« Last Edit: 23 Feb 2011, 08:04 pm by James Tanner »
Welly123
« Reply #190 on: 24 Feb 2011, 09:50 am »
Hi Russell,
james
Hi James,
I found two that I like, the first is MPDroid as you state above and the second is Droid MPD Client. Both seem to work quite well and Droid MPD Client also uses LastFM for Album and Artist data (similar to mPod for the Apple devices) and links to Amazon and YouTube for additional information.
Regards
Russell
EDIT: Yes, I also found that I must use the IP address...
« Reply #191 on: 24 Feb 2011, 02:17 pm »
SUBJECT: Samsung Galaxy Tablet – Android
OS
Feb 2011
Hi Folks,
Another device you can use to control the Bryston BDP-1 Digital Player is the ‘Samsung Galaxy Tablet’ running the (2.2) Android operating system.
The BDP-1 works well using the ‘MPDroid’ music player interface. Looks like the standard Android music player except controls Linux MPD.
Log on to the internet and go to the 'MARKET' icon on the Galaxy Tablet desktop and download the 'MPDROID APP (it’s free) by searching 'MPD'
NOTE: - currently need to put the IP Address in HOST (not- bryston-bdp-1.local)
(The Tablet will also run the Bryston ‘MINI’ application and we recommend using the Android Zirco Browser (available free on Android Market Place.    http://market.android.com/search?q=zirco.)
Bryston
alexone
« Reply #192 on: 24 Feb 2011, 05:20 pm »
James or anyone who knows,
my computer's motherboard has 2 ethernet ports. one port is connected to the router. can i use the other port to connect it to the BDP-1 :scratch:?
al.
skunark
« Reply #193 on: 24 Feb 2011, 05:38 pm »
al.
Yes it is possible that will work but configuration might be more difficult than you want to endure.  You would have to set up your computer as a bridge between two networks and if your router is a wireless router, any wireless device might not see it.   Also, you might need a unique crossover Ethernet cable between the computer and the BDP-1.
If you are out of Ethernet ports on your router pick up an Ethernet switch and connect that to the router and your computer and BDP to the switch.  The most difficult part is the physical aspect of plugging in the cables.    BTW, I actually prefer the dell business models for ethernet switches, no wallwart, and on sale over the weekends when business are most likely closed :)
« Reply #194 on: 24 Feb 2011, 05:39 pm »
al.
Hi Al,
Normally you would use one of the Ethernet OUTPUTS from the Router into the BDP-1.  Speaking with engineering they say the way you're suggesting is possible but you have two concerns doing it that way:
1. Addressing the 2 separate Ethernet ports on the computer so there is no interfearence.
2. You would have to use an Ethernet 'crossover cable' between the Computer and the BDP-1 (not a straigt through cable)
james
skunark
« Reply #195 on: 24 Feb 2011, 05:43 pm »
OS
Feb 2011
Hi Folks,
Bryston
Newsflash:  Galaxy Tablets flying off the shelves!
alexone
« Reply #196 on: 24 Feb 2011, 06:53 pm »
ok, guys. thanks!
and James: i like the word 'interfearence' because an interference can indeed become an interfearence :wink:.
al.
« Reply #197 on: 25 Feb 2011, 03:59 pm »
Hi Folks,
Some screen shots for you of the MPod App from MAC on iTouch, iPhone, and iPad with the BDP-1 Digital Player:
« Last Edit: 25 Feb 2011, 05:12 pm by James Tanner »
Napalm
« Reply #198 on: 25 Feb 2011, 04:10 pm »
I have two Blackberries but no iAnything.
 :dunno:
« Reply #199 on: 25 Feb 2011, 05:03 pm »
MPOD Setup with BDP-1:
james
