BRYSTON BDP-1/2 FREQUENTLY ASKED QUESTIONS THREAD
0 Members and 3 Guests are viewing this topic. Read 1039819 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BRYSTON BDP-1/2 FREQUENTLY ASKED QUESTIONS THREAD
« Reply #1140 on: 2 Nov 2016, 12:48 pm »
Yes. I have followed the instructions. Put a tick beside bda2 and hit Apply. The bdp1 plays the dsd file but no sound comes out. Do I kiss anything or bda2 not support dsd.
Hi
Contact Gary and he will help.
[email protected]
james
unincognito
    • bryston.com
« Reply #1141 on: 2 Nov 2016, 02:08 pm »
BDA-2 isn't dsd capable
Bso888
« Reply #1142 on: 2 Nov 2016, 06:40 pm »
Thanks a lot. I thought BDA-2 is DOP support
unincognito
    • bryston.com
« Reply #1143 on: 2 Nov 2016, 10:26 pm »
Sorry, we looked into it, but an ic responsible for the ultra low jitter hinders dsd capability
eyeshigher
« Reply #1144 on: 14 Nov 2016, 05:42 pm »
Hi,
Just started using Tidal on BDP1 connected to BDA2 via USB and AES.
I cannot get output from the AES connection, within the Tidal app on the BDP tried selecting different output options but sound only comes from USB?
Share Port (airplay) sound only comes from USB despite changing output in audio devices?
Is this normal, am I doing something wrong
unincognito
    • bryston.com
« Reply #1145 on: 14 Nov 2016, 07:33 pm »
Hi,
In Tidal settings only take effect until the next song is played or in the case of quality (lossy vs lossless), two songs.
The 3rd party renderers default to USB if a USB dac is connected during startup.
Chris
eyeshigher
« Reply #1146 on: 14 Nov 2016, 10:47 pm »
Thanks Chris for reply,
The BDP booted with Tidal settings set to "ESI Juli@ ice 1724 iec958" audio played from USB, then swapped to "ESI Juli@ice 1724" no sound nothing
With shairport how do you get usb not to be the default setting, and output to aes
Thanks, please advise
unincognito
    • bryston.com
« Reply #1147 on: 14 Nov 2016, 10:49 pm »
don't have a usb dac connected when you turn the BDP on
eyeshigher
« Reply #1148 on: 14 Nov 2016, 10:59 pm »
Thanks Chris,
Issue with Tidal not playing from AES only usb despite changing settings and playing serval songs?
unincognito
    • bryston.com
« Reply #1149 on: 15 Nov 2016, 02:14 am »
Thanks Chris,
That one I'll have to look into
Norton
« Reply #1150 on: 15 Nov 2016, 02:06 pm »
I'm thinking about looking around for a well priced s/h  BDP-1 (having owned a BDP 2 previously) for a second system
Is the following correct about the BDP1 in relation to my experience with BDP-2:
can run the very latest version of  MM software as per BDP-2
can output DSD 64 and 128 (via USB, BNC and AES?)
cannot be fitted with internal drive
can rip files from a BOT or similar proving independently powered, but not load CD into memory for replay
the lack of memory will not prevent replay of large files (e.g. .dsf) from thumbdrive?
unincognito
    • bryston.com
« Reply #1151 on: 15 Nov 2016, 07:05 pm »
The BDP-1 will work with the latest versions of Manic Moose, but support will likely get cut from Nutty Narwhal (the next release).
It will output DSD via USB only and not BNC or AES, this is a function of the new audio output device
It will play audio cd's with a BOT or USB optical drive
The size of the music file has no bearing on limitation, the number of files could effect how well the native web interface functions
Also if your unaware we have released a new unit the BDP-Pi which retails at $1295.
Chris
CanadianMaestro
« Reply #1152 on: 15 Nov 2016, 07:41 pm »
^ Ahhh....I get it now. Alphabetic software names.
Loony Loon
Manic Moose
Nutty Narwhal (LOL, great one there)
When "O" comes next....
Ooty Owl
 :thumb:
Rod_S
« Reply #1153 on: 15 Nov 2016, 08:06 pm »
or...
Opinionated Orangutan
Opulent Otter
Obtuse Ocelot
Ornery Oryx
CanadianMaestro
« Reply #1154 on: 15 Nov 2016, 09:08 pm »
or...
Opulent Otter
Obtuse Ocelot
Ornery Oryx
Only the Otter is eligible...can be found in Canada.  :green:
The others are not eligible -- found only in S. America, Texas, and Africa.
(Narwhals are good -- sometimes spotted off BC coast in Pacific).  :thumb:
unincognito
    • bryston.com
« Reply #1155 on: 16 Nov 2016, 03:12 am »
Loony Loon
Manic Moose
Ooty Owl
 :thumb:
Ornery Otter is the current plan, but as it's a version of the firmware that is 2-4 years away from existing it'll likely change
Norton
« Reply #1156 on: 16 Nov 2016, 01:29 pm »
Chris
Thanks Chris,
As I recall, my BDP2 did output DSD over spdif, before I upgraded to the IAD, so I imagined the BDP1 would too.
Will the BDP1 rip CDs as well as replay from a BOT or similar?
unincognito
    • bryston.com
« Reply #1157 on: 16 Nov 2016, 03:31 pm »
yes, we've also added an option to turn off some of analyzing tools to speed up the process of ripping significantly on the BDP-1
alegar
« Reply #1158 on: 28 Nov 2016, 06:22 pm »
Hi, I am new to the forum, I have a Bryston BDP-1 USB I have updated it to the latest firmware, I have it connected to the home network and it detects the nas sygnology I have and also the hard disks connected in USB and when I Plays a CD does not end because it is blocked and I have to turn it off and on again, you can help me, m sorry for my English,
Greetings.
mikemalter
  • Have a nice cup of coffee
    • The Computer Mutt Blog a repository of divergent computer knowledge
« Reply #1159 on: 28 Nov 2016, 08:34 pm »
I'm trying to get into the Admin settings for my BDP-1 and I don't remember what the login or password is.  Is there a default I can try.  I'ts been a very long time since I got in and wanted to update my firmware.
My build is Loony Loon 0.16.6
Mike
