0 Members and 1 Guest are viewing this topic. Read 5118 times.
Hi jupe! Congrats on your engagement, and thanks for posting!! Welcome to the fun.Use pure direct analog setting on the Receiver to remove DSP from the high freqs. Then use the speaker level inputs by connecting the sub to one speaker in parallel. Summing two together is usually not as clear as using just a single side. I recommend using right side, so most classical recordings will still work while rock and jazz records have bass in the middle anyway. Then set the sub's crossover settings to sound best with your main speakers. Start with the sub drivers placed the same distance to you as the main speakers' woofers, with the sub phase switch set to 0. Set the filter slope to 24dB. Then adjust the freq and volume to make it disappear as much as possible. Put the sub between the mains up on a speaker stand to get it off the floor for a huge improvement in bass clarity. Speaker positioning is another thing you can try which doesn't cost anything. Search AC and the web for Cardas golden ratio, Wilson speaker position, and Master Set. You'll find that the distance between the front wall (behind the speakers) and the mains is critical setting that is really important to get right. You can change the whole character of your stereo with the width and the depth from the wall. Once you get close, the tiniest changes in position and angle can have a huge effect. So far you have the cost of a length of speaker wire and a speaker stand. The weakest part of your system might be the receiver, so a nice audiophile level integrated amplifier would be a good upgrade once the money starts rolling in, like those wedding presents in envelopes. You bought speakers very wisely so you have a long way to go before you outgrow those, and Rick can help you dial in the sub too. Watch Audiogon for used JPS wires, they are awesome! SCs first, then ICs. I got some ICs for $60.The last thing would be to get another sub at some point so you can have stereo bass, but it's not essential. Marantz CD players usually have a lot of opportunities for upgrading. Some had opamp sockets to allow swapping. Some great opamps to try are 5532, LM833. Look up your model on diyaudio.com for ideas. Usually the same mods work in all CDplayers. Power supply, clock, output stage, vibration. Output transformer to replace output opamps is a nice tweak. Ask for help in The Lab when you're ready for that. Have fun!Rich
JLM is right. A switch to the Virtue One.2 or Two.2 amp will give you the best bang for your bucks.
