Audirvana - A Great New Music Player
0 Members and 1 Guest are viewing this topic. Read 7309 times.
highfilter
« on: 1 Feb 2011, 06:17 pm »
After going through Mac music players like a bag of chips, a new player I recently tried might just be my new reference player. Called Audirvana.
Pure Music still offers the best feature-set and overall usability - but I have been using AyreWave (now called Decibel) for my music playback. I found when comparing the two players, that the bass on Pure Music was more bloomy when compared to Decibel and that Decibel had more focus and sounded more natural in the upper freq.
Now, I recently tried Audirvana and it might be my new reference player. For strict music playback, it sounds amazing. Not sure if it all stems from how it uses the memory buffering or management, or what, but it sounds like it has more low-level detail, more "blackness" in the background, tighter bass (a lot more defined and tighter than Pure Music, slightly better than Decibel) and the vocal ranges and high freq. are amazing. Female vocals especially sounded more "real" than ever. I initially thought the high freq. might be a tad rolled off, but after some listening they sound crisp and quite impressive. It offers a fairly lack-luster feature-set when compared to Pure Music, but for strict listening, you should give it a try. I was impressed!  :o
I'll have to do some more comparisons on more music, as I only have been listening to it for a few days, but the initial impressions are very good. It sounds like it isolates the sound from the rest of the operating system better than the other players.
Also, I had to turn off the "Audio Device exclusive access mode" option in the Preferences to get my Tranquility SE DAC to properly play music back. I think it was trying to play at the wrong freq. or something. It is similar to the direct-control in Pure Music, where it has direct-access to the playback device. I might have to play around with different settings to make this work, but it sounded fantastic with it off anyhow.
You can download it from: http://audirvana.googlecode.com
And there's some reviews and good discussion going on, over at: http://www.computeraudiophile.com/content/New-OSX-Opensource-audiophile-player-Audirvana
Feature Set:
* Native playing of FLAC, libSndFile (WAV, AIFF, ...), ALAC and other quicktime formats (AAC, MP3, ...)
* Direct sound path, directly to the CoreAudio HAL for pure bit perfect sound
* Audio Device exclusive access mode
* Automatic sample rate switching
* Up/Oversampling capability
* Plays completely from memory
* Tracks are loaded, decoded and sample rate converted in a memory buffer before being played
* Minimizing CPU and hard drive activity to lessen sources of interference
* Gapless playback by using a double buffering mechanism (playing track and next track)
* Transparent split load for loading tracks of any size
* Background tracks loading/decoding (including sample rate conversion)
* Playlist (m3u & m3u8 formats) load/save
* Handles Apple IR Remote
* Automated updates downloading (using Sparkle)
Upcoming features:
* Dithering implementation, with tests on 16bit files improvement
* Scripting features for being controlled by Apple Scripts
* Tracks library with iTunes database access and folders crawling (mainly for FLAC)
* Remote control (through UPnP control point?)
* HAL I/O using DAC native physical formats (instead of CoreAudio 32bit float), but I don't have a DAC with such modes to develop this feature...
* Hardening playback in adverse conditions like OS swapping memory, ... that can cause clicks & glitches
* And bug fixes...
ttan98
Re: Audirvana - A Great New Music Player
« Reply #1 on: 3 Feb 2011, 04:06 am »
I tend to agree with and I have more to say when I write somethingo on media player performance under the thread, a comparison between Amarra and Pure Music.
blackhawks6
« Reply #2 on: 4 Mar 2012, 06:14 am »
I have used Pure Music for months and it has been harsh and gets tiresome. Just tried Audirvana Plus and it is incredible. Bryston 6bsst with Bryston SP3 and B&W Nautilus 803S. A+ is impressive.
MoonUnit
« Reply #3 on: 4 Mar 2012, 06:18 am »
I'm a big fan of Audirvana as well. (I haven't tried the Plus version.) It sounds fantastic, and it doesn't have some of the strange sample rate issues that I'd been having with Decibel.
wilsynet
« Reply #4 on: 4 Mar 2012, 07:58 am »
+1 for A+.
seadogs1
« Reply #5 on: 4 Mar 2012, 03:36 pm »
Well it seems like a lot of folks are very positive about Audirvana Plus, now if only Mach 2 Music would write a script for it.
wilsynet
« Reply #6 on: 4 Mar 2012, 04:17 pm »
You can only run software integrated by Mach 2 Music?
seadogs1
« Reply #7 on: 4 Mar 2012, 08:11 pm »
Willsynet, are you saying you can't run Audirvana Plus on a mac mini modified by Mach 2 Music? They used to have a script for just plain Audirvana before Plus came along, why can't they do a script for the Plus. Just for your info you can run most of the software without the script on a mach 2 music it just sounds better with a script.
newzooreview
« Reply #8 on: 5 Mar 2012, 01:07 am »
I modified one of the other scripts on my Mach2Mini to run Audirvana Plus and discovered that it sounded just as good when run without the script. If you want to try it with the script as well, send me a PM. It's just the Decibel script with pointers to Audirvana Plus rather than Decibel. I'd be curious to learn what differences you hear between script/no script.
newzooreview
« Reply #9 on: 5 Mar 2012, 01:56 am »
Also, if someone has the Audirvana script, I would be interested. My Mach2Mini did not come with an Audirvana script, and I would be curious to see if it does anything application-specific. It could be easily modified to launch Audirvana Plus vs. Audirvana. (I sent an e-mail to Mach2 a couple months ago asking about an Audirvana Plus script, but I received no reply.)
wilsynet
« Reply #10 on: 5 Mar 2012, 10:56 pm »
Are you saying you can't run Audirvana Plus on a mac mini modified by Mach 2 Music?
No, I was just wondering why you wouldn't run it without the script without waiting for them to do something special.
Yes, I imagine that it would be the case you could run it without the script.  Who knows, as newzooreview was saying, maybe there's no difference between script and no-script.
I'd be curious as to what the script does.  Perhaps it gives the application higher process priority.
Wilson
dspringham
« Reply #11 on: 6 Mar 2012, 12:19 am »
Also, recall that Audirvana+ has a bulit-in selectable start-up script that optimizes the playback system by disabling spotlight, time machine etc.
I prefer the functionality and inter face of Audirvna+ over Pure Music. It's extremely responsive and changes tracks quickly (including the switching of sample rates and raeding data into memory). Audio quality is excellent as well.
Dave
