0 Members and 1 Guest are viewing this topic. Read 15278 times.
The Gen I is basically a fairly balanced capacitor. However, some find our "balanced" slightly thin and bright compared to the more lush "colored" capacitors which would include the Gen II. While the Gen II has a nice Midrange bloom, Gen I has a slight advantage on the freq extremes (top and bottom). In many applications, larger values of Gen I bypassed with smaller values of Gen II yield a very favorable result.
FaststangWelcome to A.C.!You might enjoy reading http://www.humblehomemadehifi.com/Cap.html
Hi JT,I am not sure the article does more harm than good for several reasons. 1) I only see that the caps are within tolerance, not necessarily close in value to each other. Hopefully they are close.2) One brand cap may sound better than another depending upon the driver/design etc. With a different driver, the brand cap may need to be changed for optimum performance.3) No in depth explanation as to how the listening was performed, no variables are covered. I would personally give very little consideration to this capacitor test without in depth coverage.--------As you are breaking in the caps, see how they sound in a week or so. Cheers.
