Using HP Amplifier Section Only on Isabellina HPA
0 Members and 1 Guest are viewing this topic. Read 1897 times.
MorganE
« on: 29 Jan 2011, 02:29 pm »
Hi Vinnie,
I know that currently the Isabellina's DAC can't be bypassed in the audio chain, but I was wondering if there is a technical reason for this?  It seems to me, (maybe naively as I am not technically knowledgeable about this), that this would be a great feature in that people could put together combinations of products they liked.  An example - I am interested in a high end CD/SACD player, and I want to use it's DAC, but I need a HP amplifier.  Your thoughts on this? Of course Members' comments would also be greatly appreciated.
Vinnie R.
    • http://www.vinnierossi.com
Re: Using HP Amplifier Section Only on Isabellina HPA
« Reply #1 on: 1 Feb 2011, 03:43 pm »
Hi Vinnie,
Hi Morgan,
Thanks for your post.  No technical reason for what you mention above.
The Isabellina HPA LFP-V is an Isabellina dac, LFP-V tube stage, with built-in headphone stage and volume control.
Isabellina HPA LFP-V was optimized with the Isabellina dac, LFP-V tube stage, and headphone stage.  Analog inputs would require switching and more complexity (adding to the cost), and if you are not using the built-in Isabellina dac (connected to the LFP-V tube stage), then you are not listening to the Isabellina HPA LFP-V anymore. :wink:
The Isabella LFP-V Edition Preamplifier offers a headphone output option, as well as the Isabellina dac option (as well as hi/low gain), so this gives you both 3 analog and 3 digital inputs (as well as 2 sets of analog outputs).  More ways to configure this unit, more features, even better sound, but more cost...
Best regards,
Vinnie
