0 Members and 1 Guest are viewing this topic. Read 13578 times.
Currently it does not. But there is nothing that prevents you from using something like BDDecryptor to handle the ripping and then move files to the server. I need to do some more investigating, but I think there are legal issues here. - Jim
I've been looking for something like this for DVD storage. Any idea on cost?
This is not only a desirable device, but that's a pretty cool looking prototype, IMHO. Go for it, Jim.And oh yeah...another vote for the drawer. Slot not.
I would guess this iteration would run about $1800. There are so many options available for building this type of system, the costs can vary greatly. This is fanless, has high-end audio performance, etc. With a less expensive case and fewer or less expensive options, one could be built for less. This is very close to what I was looking for personally.- Jim
sounds reasonable. if it's good enough for you, it's good enough for us. BTW as i go through my touch with vortexbox, i am strictly 2 channel. if you burn a dvd (i would assume dvd-a) to vortexbox, does it output in 5.1 sound or does it downsample to 2 channel?
p.s. not to hijack this thread but this has been bugging me lately. we have heard about your studio work, but i can't find what you played or what band(s) you were in?
I am familiar with MKV and have done all my DVD/BR rips in this format. What bit rate are you using?
You would ideally maximize the available throughput of the network but wirelessly this is limited to less than DVD quality and you end up with this big fancy streaming machine with VHS looking video. Of course audio is going to stream effortlessly. Are you going to have hard wired gigabit ethernet?
Also, how much storage is built in? How will that be scalable? 10GB per movie is realistic at high quality.
of course you can get a VB appliance. the real big diff is that it's not a fanless device. it's not overly loud OTOH, so it's just a matter of whether or not you want that on your rack. i can hear mine from the other room when it's accessing it's drive and i think that would bother me if it was in the same room as my system.
